FS: selling as no longer going ahead with this setup straight bolt on for rb20-25 it was my mates i bought it all off him to use on my r32 its used approx 2000km before defect and EPA and he couldnt be stuffed putting it back together! Spent too much already!!
Garret 3076r turbo has surge front housing, has 4 bolt rear housing and vband clamp for wastegate
Braided line
Turbosmart 50mm progate
Custom screemer pipe
Custom Dump/front pipe
Custom Intake pipe and air filter
$2600ono bargain I say as turbo alone nearly costs that much!
RB20 Custom made forward facing plenum with bigger throttle body its of an SS similar to greddy style (Is getting sprayed black atm) 700ono
Custom surge tank with Bosch 044 pump and near new speed flow fittings
Siemens 750cc injectors
Has some hoses as well
1500ono
Wolf 3D V4 ECU with hand controller(rare can't find any other for sale), loom for rb20 and M&W ignighters
1500 ono
Brand new in the box BLITZ nur spec-V cat back exhaust 750ono paid 900 for this
Car pulled 296kw with supporting mods this setup has way more potential good for you drifters or sick street weapon if you want to take the risk like my mate did
If you want more pics just inbox me! or sms me on 0433476929
Thanks
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
    • By "reverse flow", do you mean "return flow"? Being the IC having a return pipe back behind the bumper reo, or similar? If so... I am currently making ~250 rwkW on a Neo at ~17-18 psi. With a return flow. There's nothing to indicate that it is costing me a lot of power at this level, and I would be surprised if I could not push it harder. True, I have not measured pressure drop across it or IAT changes, but the car does not seem upset about it in any way. I won't be bothering to look into it unless it starts giving trouble or doesn't respond to boost increases when I next put it on the dyno. FWIW, it was tuned with the boost controller off, so achieving ~15-16 psi on the wastegate spring alone, and it is noticeably quicker with the boost controller on and yielding a couple of extra pounds. Hence why I think it is doing OK. So, no, I would not arbitrarily say that return flows are restrictive. Yes, they are certainly restrictive if you're aiming for higher power levels. But I also think that the happy place for a street car is <300 rwkW anyway, so I'm not going to be aiming for power levels that would require me to change the inlet pipework. My car looks very stock, even though everything is different. The turbo and inlet pipes all look stock and run in the stock locations, The airbox looks stock (apart from the inlet being opened up). The turbo looks stock, because it's in the stock location, is the stock housings and can't really be seen anyway. It makes enough power to be good to drive, but won't raise eyebrows if I ever f**k up enough for the cops to lift the bonnet.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
