1991 Black Rb25 S13 - 450Hp Rb25, Dmax, Absolute Weapon !
I bought the car as a shell and built it from there. Huge list of modifications do not want to know price to build car 95% of all parts purchased brand new. This car drives amazingly and is a complete animal, not to mention has the looks to match. You will notice in the pictures the unfinished front guards. This is due to not having wheel lips for my 18" equips, so i never got around to completing a set. Some aggressive FRP guards could be bolted on to set it right off ! Car is always looked after / garaged and serviced only with Mobil products. Also gets plenty of attention at the track =P
I too have no problem sending this interstate I've used a very good company before bringing a car up from VIC.
Price = $22000
Engine - Build Buy KJ Motor Machining, Kohen builds drag racing engines to blueprint with extreme tolerances, the motor cost a f**ktonne.
The car had no Odo, but it wouldn't even be close to 5000km, gearbox was rebuilt at same time as motor. It was also built for 30psi roughly 600HP.
Mahl pistons
Scat rods w arp fasteners
Mls headgasket
Acl mains
Arp big end fasteners
Arp head fasteners
Arp main fasteners
Ati balancer
Supertech valve springs
Re-welsh plugged
Tourqe plate honed to .20thou
Oil galleries drilled larger / tapped
Valve seats re-cut / valves faced
Crank collar welded / machined / re-ground
Block n Head re-faced
Balanced, Rotated n blueprinted.
Head ported / knife edged
Garrett Gt3076 .8 (rebuild by garrett when engine was built)
Hks 264 9mm cams non-vct
6boost forward highmount - head wrapped
Turbosmart 38mm Wastegate
Freddy plennum faced and port matched
Decs 550cc inj
Q45 TB
Carbon Fiber Cam cover & plug cover
Nismo FPR
Mezier waterpump (controlled by haltech to act as thermostat)
NPC lighten flywheel n 5 puck cushion
Rebuilt 25box
PWR xflow GTR radiator
PWR custom Intercooler
PWR oilcooler w. Enzed Lines
PWR powersteering cooler
Motor into firewall 1.5 Cyl
Fuel cell w. Surge & Dual Walbro pumps
1.5 to 2" screamer pipe
Full 3" Exhaust wrapped
Extreme Custom Engineering 2x4" twin tip exhaust
Suspension
PBM Coilovers 10/8
PBM LCA front / rear
PBM toe
PBM camber
PBM castor
PBM traction
PBM cradle risers
Driftworks Hubs (modified for dual caliper)
Whiteline Adjustable sway bar front / rear
Extreme Custom Engineering catch can, with drainback
Drivetrain
rb25 box (rebuilt same time as motor, new 3/4th synchro & bearings all round) by DANSTRANS
Urethane Mounts
npc lighten flywheel
5puck clutch
Quartermaster hydraulic throwout bearing
Hardy Spicer 1 piece tailshaft
Kaaz 2way
R33 Gtst Brakes w. DBA rotors w. QFM pads
Dual Calipers for separate Hydro
Electrics
Haltech PS2000
Racepak IQ3
Wideband Controller w. Sensor
Boost Control Solinoid
Oil Pressure
Oil Temperature
Water Temperature
Air Temerature
3bar Map Sensor
Haltech TPS Sensor
Standalone LS1 coilpacks with custom Eagle plug leads
MR2 Electric Power steering pump mounted in boot.
Single engine loom plug on firewall
Full rewire with a EZ kit
Switch panel's control everything
Exterior
Onevia Conversion
Tinted red taillights
Dmax type 3 kit
Dmax type bonnet vent
Dmax roof lip
Custom Metal Widebody
Painted Black
Interior
Bride ZetaIII drivers seat
PBM hydro w. Tilton master
S15 Dash
Tilton floor mount pedal box w. Tilton masters
Chassis
Fully Stitch welded, underside aswell
Rear firewall, due to fuelcell
Notched firewall for motor to sit back 1 1/2 cylinders
Framed rear end, for fuel cell
Huge front tubs
Rear Tubs w. metal widebody
Tubed front Reo, sits tight in frontbar
Wheels
Front - 18x8.5 SSR Vienna
Rear - 19x10.5 +12 Varrstoen (x4)
The work equips are not included in the price but could be negotiated.
Power
450rwhp @ 17psi tuned by Chris @ Bob Romano's
Spares
2 x 5bolt drive shaft
4:1 Diff gears w. housing
2 x Tilton master cylinders
Tilton Remote brake bias adjuster
Steering Rack
Whatever else i can find for it
Pictures
I'm sure there is allot I've forgotten i can be reached on 0420 855 181 if you have any questions or want to check it out. I will continue to drive this at the track until sold.
I've f**ked up the price its $19,500 with the SSR Viennas / Varstoens.
$22,000 with the equips (18x9.5 front 19x10 rear) there not shown in the photo, will have updated pics soon.
chrome equips 19x10 19x11 are $2800 extra
Edited by 32_Dave
bump, can do an extreme package
car + 8 work equips + 4 varstoens + dual axle trailer (tyre rack, elec winch, toolbox) = $29,000
will include every Nissan part and car related parts i own.
  • 1 month later...
  • anyone wanna swap a basic s13 or s14 + cash?
  • something along the lines of Sr manual, t28bb, coil overs, 2way, castor / camber / toe arms
  • 1 month later...
    • Ha ha ha, that's fair mate! We have the crackhead dogs now. Mainly because the missus wants the crazy dogs while she still has the energy and capacity to be able to keep up with them! Ha ha our current two are both Working GSD, there brothers and sisters (from the same litters) are in Police, Corrective Services, and I believe one did end up in defence force too. They're wild and fun, yet right now, both curled up asleep on the lounge room floor while we watch some TV. Mal is very likely the next dog (unless I get my couch potato guardian dog 😛 )   What are your Kitties names? Are you planning some house work, like those high kitty shelves, built in scratching post, and some cat passages from one room to another room?
    • Maine Coone, did look at but to big and fluffy As for performance dogs, we had Mals at work, performance dogs are fun to watch, but, way to much work for this old rooster
