Hi Guy's
My R32 GTR is up for sale, don't really get to drive it any more so it's up for grabs. has a long list of mods and never been to the track or drags Been fully respayed about a year ago. Bought the car off a forum member PhilGTR who did the engine rebuild. Had all the recipts but can't find them at the moment. But will keep looking for them .It has a fully forged re built engine Mods are as follows.Also comes with a set of standard r32 GTR wheels. Bargain at this price. Please note the price is non negotiable, Will not drop the price at all.Very Very quick car. call me to ask any question 0411 574 412.
ACL Forged Pistons
ACL Piston Rings
ACL Big End Bearings
ACL Main Bearings
Ported and polished head
Stock polished crank and rods
Bored and honed Block
N1 Oil pump
N1 Water pump
Tomei Oil Gallery restrictor
Gates timing belt
New engine gaskets all round
New Thermostat
New NGK spark plugs
R34 GTR injectors
GT 28/60 - 7 Turbos
New Rod bolts, welsh plugs
Fresh paint on rocker covers
3" Trust Front pipe and Power Extreme II Cat back Exhaust
3" Metal cat
Twin Apexi Pods
Apexi Power FC & Hand Controller
Greddy Profec B Spec II boost controller
Nismo fuel pump
17" deep dish rims
adjustable cam gears
SARD 600 cc injectors
Splitfire coilpacks
Jim Berry clutch rated to 400kw
im sure there are a couple of others i have forgotten. Car is making 322rwkw and just needs a set of cams to really open her up.
Cheers Guys,
https://www.sau.com.au/forums/topic/412509-r32-gtr-for-sale-14000-sydney/
how much rego left mate? also what year model? does the AC work? any problems at all? im interested just waiting on my motorbike to sell (hopefully this weekend coming) thanks :)
Edited by barnoon
Hi Mate,
It has 11 Months REGO and is a 1990 model, the body is perfect. The only problem with the car is a slight oil leak from the oil return line from the front turbo, easy fix, just change the oil return hose. Also 4WD has been disengaged so only rear wheel drive :yes:. 322 KW at the rear wheels means allot of fun.
Price Drop to 13K but has to be gone by the weekend. Really need the cash.
Guys oil leak is fixed, Took the car to Matt at F&E he said that the 4WD issues seems to be the TPS as the pump is working very lazy. So that's a $400 fix guys, other than that the car is Great. 13K is a bargain!!!
    • ..this is the current state of that port. I appreciate the info help (and the link to the Earls thing @Duncan). Though going by that it seems like 1/4 then BSP'ing it and using a bush may work. I don't know where I'd be remote mounting the pressure sender... to... exactly. I assume the idea here is that any vibration is taken up by the semiflexible/flexible hose itself instead of it leveraging against the block directly. I want to believe a stronger, steel bush/adapter would work, but I don't know if that is engineeringly sound or just wishful thinking given the stupendous implications of a leak/failure in this spot. What are the real world risks of dissimilar metals here? It's a 6061 Aluminum block, and I'm talking brass or steel or SS adapters/things.
    • And if you have to drill the oil block, then just drill it for 1/4" and tap it BSP and get a 1/8 to 1/4 BSP bush. The Nissan sender will go straight in and the bush will suit the newly tapped hole. And it will be real strong, to boot.
    • No it doesn't. It just needs an ezy-out to pull that broken bit of alloy out of the hole and presto chango - it will be back to being a 1/8" hole tapped NPT. as per @MBS206 recco. That would be for making what you had in alloy, in steel. If you wanted to do just that instead of remote mounting like @Duncan and I have been pushing. A steel fitting would be unbreakable (compared to that tragically skinny little alloy adapter). But remote mounting would almost certainly be 10x better. Small engineering shops abound all over the place. A lathe and 10 minutes of time = 2x six packs.
