Fs: Quality Bits Inside- Td06Sh-25G, Id1000S, Z32 Boxes, Progate 50Mm Etc
Plenty of bits below to suit RB's and skylines...
410RWKW/550RWHP SR20 Head Setup!
- S13 SR20DET Head
- Recoed, port and polished
- Tomei Procams
- Naprec Re-inforced Rocker Arms
- Tomei Solid Lifters
- BC Valve Springs & Titanium Retainers
- Tomei Rocker Arm Stoppers
- Tomei Adjustable Cam Gears
Head will come shimmed to GT Garage specs. Drop it in and away you go!
$2.5k
- Haltech PS1000 (near new)- $1400
- ETS SR20-RB25 Gearbox Adapter Kit (2 x Z32 Gearboxes, 1 piece tailshaft to suit S13/180sx, 2 x machined bellhousings, adapter plate, gearbox mount, all nuts & bolts)- $2,200
- ORC 559D S13 SR20 Twin Plate Clutch (done four events)- $1,200
- S13 SR20 Greddy Inlet Manifold, 80mm Throttle Body & Gizzmo Phenolic Intake Manifold Gasket- $650
- Greddy LS Intercooler mounted upside down with custom Intercooler Piping- $650
- 4 x ID1000 Injectors (virtually new), alloy adapters & SR20 Top Feed Rail- $500
- SR20 Powertune Steampipe Manifold- $650
- Turbosmart 50mm Progate- $500
- TD06SH-25G 10cm turbo (two events old w/ welded 90 compressor outlet)- $700
- Braided wastegate lines (5 x -4 lines in total to suit EBC setup)- $150
- Full S13/180sx/R32 80mm custom exhaust to suit high mount- $700
- SR20 Ross Harmonic Balancer and Crank Trigger Kit (replaces Crank Angle Sensor)- $1200
- 3 x Nissan OEM SR20 Crank Angle Sensors- $100 each
- AzCustom custom S13/180sx Oil Catch Can & -10 braided lines and fittings to suit SR20- $250
- S13/180sx Embleton Engineering Aluminium Radiator Overflow Tank- $70
- SR20 Billion Blue Radiator Hoses- $40
- Trust 48mm Twin Core SR20 Radiator- $550
- 4 x MSD Coils w/ 8mm leads to suit S13 SR20DET (coils mounted in cabin)- $550
- S13 SR20DET Starter Motor (just rebuilt)- $150
- S13 SR20DET Alternator- $50
- Apexi Power Intake Air Filter- $50
(other parts can be included at request I'm sure there's more....)
PM for more info/to purchase or 0408782632.
Ben
  • 3 weeks later...
Hey mate I've given u the cash for that z32 gearbox and conversion kit, and I still haven't received any con note number details or been told if its been sent, what's the go?
Peter it's fine Dave was just stressing. We hadn't spoken for 24 hours.... I hardly doubt I'm going to scam anyone lol!
BALLER FRUIT BELOW FOR 180SX/S13/SR20/EVERYTHING!!!!
- 4x 16x8 +18 Rota Grid (White) WITH tyres! $700
- S13/180sx Kazz 2 way diff in ABS housing: $700 ($600 centre only)
- S13/180sx Bilstein front shocks WITH cusco camber tops- $200
- S13/180sx dash non cracked mint condition- $250
- S13/180sx Climate Control Unit- $100
- 180sx Type X Carpet and Rear Seats (mint)- $offer
- S13/180sx 25mm lengthened front lower control arms (ball joint inners)- $250/pair
- 180sx Type X seat belt set- $150
- S13 SR20DET Head
- Tomei Procams
$2.5k
- Haltech PS1000 (near new) with ANY patch lead of your choice!- $1400 (RRP- $1900)
- Z32/300ZX Gearbox to suit rebuild as 2/3/4 synchros all need love (gearbox still works)- $600
- Greddy Inlet Manifold, 80mm Throttle Body & Gizzmo Phenolic Intake Manifold Gasket- $650
- Powertune Steampipe Manifold- $650
- Turbosmart 50mm Progate- $450
- TD06SH-25G 10cm turbo (two events old)- $600
- Full 80mm custom exhaust to suit high mount- $700
- Ross Harmonic Balancer and Crank Trigger Kit (replaces Crank Angle Sensor)- $1200
- 2 x Nissan OEM Crank Angle Sensors- $100 each
PM for more info/to purchase.
    • I might just check it out.. A Q among all those skylines.. lol
    • Time will tell, they're doing all the admin stuff at the moment. I've submitted all the required details, photos, etc.   I was under the impression that DC coupling is the best approach, i.e.: Solar Array -> Battery Invertor -> Battery  Where as AC Coupling is simpler, however less efficient, i.e.: Solar Array -> Solar Invertor -> Battery Invertor -> Battery
    • The price is really great for that kind of capacity. I thought similar setups cost way more. How's your efficiency been with the DC-coupling? I've heard sometimes there can be a bit of a performance loss.
    • Long time no random post about shit. So I went down this deep deep rabbit hole of battery storage for the home, ended up locking in a 41.9kWh Fox ESS EQ4800 with 9 units stacked. Battery uses Lithium Iron Phosphate, similar to what you find in those deep cycle boat/caravan batteries. And yes, why did I go with a cheapie brand and not like Synergy? simply because I don't plan to stay at this house for more than another 3~5 years.  The entire install, DC coupling (removal of existing invertor, connecting the current 6.6kW array direct to the battery invertor), new 8kW invertor is $6K all up (after all the rebates etc.). Going with this lot: https://www.aussiesolarbatteries.com.au/ It did seem a bit too good to be true, however seems like the Whirlpool community has vetted it and when it comes to this kind of stuff, they seem to be all over it: https://forums.whirlpool.net.au/thread/9pxj8482?p=38   I've requested for the battery to be installed outside, next to my meter board and not inside - rather have it combust and ignite outside lol.
    • In Vic it would be a defect regardless of whether or not you cut a hole in the sheetmetal for the return pipe. The rules in Vic are shitful, and are generally interpreted as you can "make 2 mods to the intake system". Putting an FFP and an FMI onto it will almost certainly be seen as some huge number of intake mods. You really need to speak to an engineer before doing this stuff in VIC.
