Hey guys I have a r32 sedan MAYBE up for grabs. Now just to make a few things clear i LOVE this car to bits, I have spent 1000's on it and will not let it go cheap if no one pays or offers another car of value to me plus cash i will not seperate . My reasons for sale are
1. I want to buy a house and the only way to get the money together would be to seperate with the 32
2. I travel at least 60k to work 7 days a week and some days 120k
3. As i travel alot its not ideal (easy to speed and be a numpty in, bit bumpy as its low, defectable)
4. MONEY its a skyline while i get 400ks to a tank its always bp ultimate ran through it which adds up quite quick with all the travel
If i havent scared you off yet lets get into the good stuff.
ENGINE / RUNNING GEAR-
-S1 RB25 Conversion done before i bought it. Believed to have 130000k. Runs beautifully and has buckets of power
-Turbosmart manual boost controller, Running 11PSI of boost
-Previous owner said it was tuned to 211kw, I have no dyno sheets for proof BUT can see it does pull very hard
-Serviced every 5000k with quality nulon oils and additives , expect the gearbox and diff which runs with redline shockproof (only serviced twice in my ownership)
-Diff has just been reshimmed very tight and never singles, Only skips when pulling out of the driveway when cold
-STD turbo
-Cold air box with a pod inside
-Clutch went pop around 5000k ago replaced with extreme HD, POS rb20 box went a week later
- 80000k RB25 box conversion was put in by me. Speedo conversion done,Solid shifter bush, new slave, custom tailshaft, custom crossmember, done about 4500k
-Very large FMIC
-3'' stainless blitz exhaust sounds very tough but not over the top, also have a 4" jasma exhaust to
I feel like there is a few things im missing but a start
BRAKES / SUSPENSION / BODY
-I recently just did the brake system on the sky which included. R33 GTR slotted and cross drilled rotors up front, Slotted back, EBC Redstuff pads on all corners, new fluid and bled. The most responsive brakes i have used, they are brilliant 2 weeks old
-Shortened shocks and springs which sits very low but not ridiculous, all shocks in good nic
-20 percent window tint all round looks moist
-Paint is very fresh and is a custom respray in Mazda 3 red paint code 27a, Brilliant red which glitters in the sun
-All four guards have been rolled and flared HEAPS had 9.5 all round at one point
-Sparco ns11 wheels on atm 8.0" on front 9" at back which doesnt do the flared guards justice but suit the car well
- Tein Adjustable camber arms front and rear
-stock kit (my favourite personally)
INTERIOR AND STEREO
Interior lets this car down a bit, missing vents, slight bubble in dash suppose it is an 89 model
-Sport wheel
-33 seat (lumber support)
-Kenwood headunit with aux
-2 2000w earthquake amps one monoblock one 4 channel
-2 kenwood 1200w subs
- alpine type s splits all round with tweeters up front
Radical sound system
$12000.
Please dont tell me if you think this is overpriced, I dont car what you think as i dont want to let it go unless i get what i want I AM IN NO HURRY and as stated its a EOI. Every time i go out and see this car i smile, I just love the 4dr look and it would be an incredible shame to see it go but i would like to buy espcially while the home owner grant is around still. SA REGO BTW
Will get more photos later
  • 2 months later...
Okie dokie, some mods i forgot
So the HD clutch crapped out, Just put a Jim berry full monty clutch in rated for 350kw. Stock pedal feel with a button feeling to it if that makes sense.
-bosch 044 fuel pump
-hicas lock bar
-R33 front LCA's
-Tein Castor rods
-nolathane control arm bushes
-Rack spacers
-Cradle bushes + pineapples + cradle mods
-40mm spacers in the back now
-gtr bonnet
-Dildo shifter
Now i understand 12 is a bit steep so price drop down to 10500. My phone doesnt take a great pic but here are some snaps
Cheers buddy! Got to stop spending money on it !
Just got new
-tie rod ends
-steering rack mount bushes ( made an incredible difference)
-two front tyres fitted
-wheel aligned at the front
also found a 4" jasma exhaust in the shed as well !
Someone make an offer e.g minus sound system 10g.post-87113-0-48318300-1360827020_thumb.jpgpost-87113-0-76641800-1360827035_thumb.jpgpost-87113-0-44696500-1360827047_thumb.jpgpost-87113-0-20169700-1360827060_thumb.jpgpost-87113-0-10531100-1360827070_thumb.jpgpost-87113-0-12086800-1360827007_thumb.jpg
Leaking exhaust manifold. Poo balls. I will put a new gasket, new studs, new nuts and machine the manifold within a month if all goes to plan (never does though). BUT if interested to take as is. $9500 !!! once fixed it will go back to its normal $10500
Oh and fresh 3 months SA rego went on a week ago
Starting to get a bit more interest ! More so after cash as i have found a house i like, but because this is my only car/daily will defiantly trade in your vr,vs commys el,ef coons etc. Holla at me if u have a decent wad of cash plus a car to trade in as well !
Oh and on the 22nd of march an order for new cometic manifold gasket, 3" dump and front pipe, all turbo gaskets and exhaust gaskets, decat, new manifold studs and the manifold will also get machined !
    • Ok guys thank you very much. GCG highflow it is then 🙂
    • forgot to mention that when it does this it does not kill the engine, but I have not kept the pedal down long enough to let it, as I see no reason to beat up on it as its got to be something simple, small and dumb causing this.  And as soon as I let off pedal, the engine returns to its normal super smooth operation and rpms re-stabilize quickly, once below 4k.
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
