Hey guys
Got a weird problem with my m35 250rx. I.ve recently replace a seal in the outer housing unit in the rear transfer unit as it was leaking. Ever since it came back from the mechanic, the car had a weird roughy ride after 60km and become very noticable traveling more than 100km where the the steering had a slight vibration and very noticeable noise. I've since taken the car back but they can't seem to find the problem. We had rebalanced the tyres, swap with the back to front. Done alignment twice at two different places. I had since taken the car to another mechanic and he checked the front assembly and they said there is nothing wrong.
Lately I've notice that the front left brake makes an annoying click/rubbing noise when braking close to a stop. When going downhill braking the car wobbles under brake but I am not sure if this is related.
I was told that tyres could be the problem but both workshop says the tyres are good. They check bearing and it's okay. One of the bushing in the front left lower connected appears to be on it's way out so I am not sure what to do. Any suggestion?
Rear shaft out of balanced?
I bet they didn't mark the position of the tailshaft, diff and gearbox flanges when they removed the tailshaft.
I realise it shouldn't make any difference; but sometimes it does.
The wobble in the brakes will be a front rotor with uneven pad material buildup. It feels like a "warped" rotor but it is actually different areas of the rotor having different amounts of friction. Machine the rotors, and it will disappear.
Disc rotors almost never actually warp; it's a dodgy diagnosis if someone say it.
Generally a worn wheel bearing will cause the brake problem.
There will be a rusty mark where the flanges meet, so if that lines up you can only have it one of two ways. (front half anyway)
I have tried mine in different positions with no vibration, perhaps my tailshaft is well balanced?
The wheel bearings just make a grinding noise, usually it gets worse as you go around corners.
Vibration could be uneven tyre size causing the attessa to play up but if it only happened after taking the tailshaft out, perhaps they dropped it? Where are you located? I have a complete tailshaft here, you could try swapping it over if you are local.
The brakes just need machining, $25 a disk I think if you remove them.
  • 1 year later...
Hey mate..
Did you get this sorted?
I'm having similar issues. From about 60kms to 70kms, there is a noticeable vibration, particularly within the cabin as the centre console starts to rattle. After 70kms it disappears. The steering doesn't vibration though, making me think it may be the transmission.
All 4 tyres were changed just under 2 months ago along with a wheel alignment. Brakes calipers and disc are brand new too.
Anyone have other ideas?
Cheers...
If the steering wheel doesn't wobble, good chance a rear wheel is causing the vibration. Did they mention a wheel had a buckle?
The centre tailshaft bearing could cause similar symptoms if it were flogged. You need to get underneath while it's on the hoist at 70. ;)
    • I was only looking because I saw some drops on the ground but it wasn't alot. Recently had it serviced will ask the mech to confirm. Find it strange that it looks standard though, can see in another photo of a random box
    • So...not sure if you know if that has always been there or why you went looking. It could be old damage from a clutch explosion, or even just the gearbox got dropped somewhere along the line. Basically, you should seal it up to stop oil and dust getting into the bellhousing, but it doesn't matter too much and is not structural. I'd suggest something like a glob of JB Weld. BTW what gearbox oil are you running, I would guess the breather has been spewing it everywhere.
    • Hey Duncan thanks for your reply. Sorry mate I know the photos are shit.  Took another photo for reference. Seems the casing does have a hole in it looking on the net, fluid seeping out. Added a photo
    • Very hard to make out what you mean, is it the squarish hole with redline shockproof (probably) under it? Is that pic from on top of the engine with the firewall to the left of pic and engine to the right? Either way, spray the area liberally with degreaser and try again, maybe circle the part you are worried about
    • Hey all, Noticed I have a hole on top of which im guessing is my transfer case/gearbox. I can see it from the middle of my firewall looking down. S1 R33 gtr Any advice or can pinpoint what this is/caused this?
