Ive got a few parts off my r33 gtr for sale
Item1:
Genuine abflug carbon rear diffuser
Purchased January this year, done 3000kms of driving
Couple small scratches on underside n wheel arch from stones at SAU nats
everything you can see is still in near new condition
this is 100% perfect fitment (zero gaps) n can be fitted in half hour
pretty sure u cant buy these anymore, no longer listed on RHDJapan
cost me $1700
$1000
Item 2:
Carbon fibre 400r front lip
purchased January this year, done 3000kms of driving
couple of grazes on the underside due to my steep driveway but nothing major
perfect fitment on my genuine front bar
near impossible to find outside the uk and shipping fees are ridiculous
cost me $1000 delivered n took 5 weeks
$800
Item 3:
Genuine Trust/ Gracer side skirts
some scratches on underside and wheel arches from rocks
what u see when looking at them is in 100%perfect condition
painted midnight purple
these retail in japan for $500 then add delivery on top plus paint
$500
Item 4:
Carbon fibre Ztune bonnet with aerocatch bonnet pins
Fitted only 2 months ago, painted by Peter at Bodyform
100% perfect condition
Painted in midnight purple with the vents left in carbon fibre
comes with under tray for the vent
Has do luck bonnet lip fitted aswell
These bonnets are rare to find in carbon for r33's,
cost me $1300 for bonnet $100 or lip n $90 for pins and $450 for paint
$1100
Idealy i would like to sell all of this as one kit as it all goes together realy well
will work out a better price if sold as a bundle
If you think the price is too high then fine, dont buy them. but i challenge anyone to find this stuff at a cheaper price.
if you can then go buy them
All items are pick up only
Located in Wollongong NSW
https://www.sau.com.au/forums/topic/415207-r33-gtr-body-parts/
treat yourself to a christmas present
rare and hard to find body parts dont come around to often
i have only ever seen 1 other abflug diffuser for sale on this site
  • 3 weeks later...
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
    • The video for the servicing and fuel filter change can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44 One of the main jobs I wanted to do before the car officially went on the road, was to remove the awful looking blue silicone hoses. There's nothing wrong with having coloured silicone hoses, but I realise as I'm getting older I prefer monotone engine bays with a splash of colour on the engine cover(s). I cover this in a lot more detail in the Youtube video, so unfortunately there's limited photos of the process. The intercooler, upper radiator, boost vacuum and upper breather hoses were all changed to black silicone with mikalor clamps. The only blue left is a blanking cap at the back of the inlet manifold and the GReddy pulleys (which will be replaced for stock when the cambelt gets replaced) While the intercooler pipes were off I gave them a quick clean/polish too A before photo I do have a replacement air filter on its way. Fuse box covers were painted blue, they're now satin black Another job on the list while the bumper was off, is to add some mesh https://live.staticflickr.com/65535/54737966256_99b28bfa30_c.jpg[/img] I was hoping to use some thin wire to secure it, but it seems I've misplaced it and the wire I had was too thick to twist easily. I ended up using cable ties for the time being https://live.staticflickr.com/65535/54737131882_c2b7989dcc_c.jpg[/img] Was pleasant to see this https://live.staticflickr.com/65535/54737131627_8b2aab13b3_c.jpg[/img] The last thing to do was to fix the front grill and re-mesh that to match but I ran out of time The Youtube video can be seen here: https://www.youtube.com/watch?v=R4FsF6tgizE&t=23s
