urrrr.... sorrry
ok i know this question has been asked before but i just need to clarify...
me and a mechanic mate are rebuilding my engine, and putting on a new turbo. Seems the most popular choise is an HKS 2530... i want to be getting around the 230-250RWKW mark out of it. What exactly will i need to run this turbo? As far as i'm aware it will bolt straight? Can i use an s-afc or do i need something like a power FC? obviously injectors need to be upgraded, but do i need a new fuel pump? I want it to be reliable and so i'd rather do everything properly.
finally, what sort of money would i be looking at?
any help would be greatly appreciated...
https://www.sau.com.au/forums/topic/41528-help-with-turbo/#findComment-851603
Heaps of people going down the 2530/2535 path of late.
You'll definately need to upgrade the fuel pump look at Bosch replacement, as far as injectors go you'll be right on the limit the stock ones if aiming for 230-250rwkw, so If you've got the cash definately go for bigger injectors. If you go injectors then your gunna need a PFC, as the stock ECU will freak with bigger injectors and a Z32 AFM attached
2nd hand 2530 <$2000
2nd hand PFC/BC/HC <$1600
Injectors <$1000
Z32 <$400
Bosch pump <$400
https://www.sau.com.au/forums/topic/41528-help-with-turbo/#findComment-851835
This is being quote from Sydneykid:
http://www.skylinesaustralia.com/forums/sh...ight=power+rwkw
Read 2nd post, exactly what you are after. just choose a turbo basically. either highflowed or hks2503 (yes 2530 is direct bolt on) not sure if anything else needs to be adjusted (ie oil/water lines)
https://www.sau.com.au/forums/topic/41528-help-with-turbo/#findComment-851845
im summary
gtr fuel pump (or equivalent)
gtr intercooler (or equivalent)
twin plate clutch (or equivalent)
boost contoller (or power fc boost kit)
full exhaust, hiflow cat, front pipe and dump pipe
z32 air flow meter (or perhaps even q45)
powerfc
tomei cams (or hks etc.. equivalent)
standard air box with hiflow panel filter (no pod in engine bay)
bigger turbo
either highflowed stock one or hks2530 or ax53b70 (possibility?)
the rest of stock parts and untouched engine should do 250rwkw fine
all up including fitting and tuning is around 10k
https://www.sau.com.au/forums/topic/41528-help-with-turbo/#findComment-851848
Mate you need a stand alone ECU once u start boosting over the 200rwkw stage...i wouldnt recommend a piggy back ecu such as safc or emanage.
Have to change fuel maps, timing, air flow etc..
Dont buy a pggyback system...waste of money...
i recommend u purchase a powerfc or microtech , autronic etc something around those types
+ you have to upgrade your injectors if your trying to achieve 250rwkw
Basically what the guys said above u have to do...
https://www.sau.com.au/forums/topic/41528-help-with-turbo/#findComment-851866
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
