Give me a few weeks to build up the confidence to try this clutch again. Don't wana b pulling a box every week.
Haha poor clutch not good to hear after last week man, but yer took a girl down with me tonight lets just say she wasn't impressed with the lack of cars... D'oh :/
Cheers for that, i'll let yas know when i head out that way
To easy bro :)
Just a heads up to anyone that was planning on attending the test and tune tonight, the meeting has been cancelled due to track clean up and poor access :)
TEST AND TUNE FOR 30/1/13 CANCELLED
Do you know if they are still having powerplay this sat at qr?
As of tuesday at 5:58pm it was still on... And that's coming from Gup
Edited by Captain Natro
im going to go for a few runs in March here, never actually draged on the strip before, can someone give a noob a rundown on staging, burnouts ( are they even needed ) ? tyre pressures ect specific to willowbank ?
Also what is needed to run, just a helmet? what spec does it need to be?
Old bud will wave you out of the staging lanes at which point you roll out and wait behind the water traps the guy at the water traps will signal you to come forward and do your burnout (if your on street tyres just a few hard turn or just avoid the water altogether as there is very little grip to be gained by bagging the hell out of a set of street tires... Plus everyone will think your a nob jockey if you do a 30 second standstill :P)
After the burnout creep up towards the lights when ur in first stage the top pair of yellow lights will come on, at this point you only need to move about 10-20cm forward and you will be fully staged.
The starter will then drop the tree and as soon as u see the last yellow light drop the clutch and off you go, take the first return road and go around and do it all again :thumbsup:
  • 1 month later...
How'd you go mate?
Ah dang, had a couple of cars go down with us. No records broken only casualties.
Yeha took down the dirty 30 for a spin, no 11 just yet still running 121-123 mph passes so I must just have crap driving
Haha put an auto in.... Driving issues solved ;)
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
