Yeah, my ex wife said something along those lines when she didn't want me to know where she was going!!
Oh well, so long as you give her a jump every so often, turn her over from time to time, keep her lubricated then get into her and give her a good going over regularly ... you should be ok .. :D
Put some fresh oil in the diff, and went for a cruise.
Very happy with my alignment. One thing i need to fix is a very slight drift to the left.
But it feels like a Ducati.
Ever ridden one? Man, they just drop into the corners and stick there.
The way they sort of suck you down and balance at the lowest point, feels soooo gooood..... now my 32 is a bit like that.
A little tweaking and it will be perfect.
I cleaned it after about 3 weeks ( haven't had time :( ) then took it for a drive, followed an old SS then he thought he was a Drift King... completely lost it, then found out that my brakes are not to great.... just pulled up in time! so after that fright I decided to go home ....
Scares the sht out of you doesnt it..... :laugh:
And thats why you drive with appropriate safety margins.
You know what i mean? Like enough room to stop or dodge, when sht goes wrong. And it will go wrong sooner or later.
Not just other cars, but you driving down a road vs the environment.
Its good when you can learn without paying for it. (crashed car or broken bones) :thumbsup:
I think it was the first time I didn't leave enough room, its always little mistakes that you pay for...
it would have been about half a metier between us when I finally stopped... thank god for the car behind me had better brakes! she would have wet herself, she looked pretty young, maybe around 17, I think she was more worried about hitting a skyline :P
At every service ... I always have brakes checked, fluids .. pads .. roters, ensure all is clean and working well, Mik is 110% right there is never a time you need them to 'just' work, you always need them to be perfect. Same goes for tyres, your brakes sorta need them to lend a hand when things don't go right .. :wacko:
Hahaha...
Brakes only need to work when you want to stop.
Tyres only need to be ok when you're stopping, going or turning.
Flat tyres are fine. After all, they're only flat on the bottom. :laugh:
but seriously, I thought my brakes were fine (but a little different feeling from time to time) <<---- this is wrong. :/
new fluid and they are very consistent now.
Hahaha...
Struth!! we've done some seriuous work on the brakes today mate :3some: .... cheers :cheers: time for refreshing beverage.
Im getting a vacuum pump so i can do it easier, therefore more often.
http://www.ebay.com.au/itm/BN-Hand-Held-Vacuum-Tester-Pump-Brake-Bleeder-Turner-Kit-Car-Motorcycle-/310821867722?pt=AU_Car_Parts_Accessories&hash=item485e6d50ca&_uhb=1
Also waiting for a snowfoam lance.
Santa brought a pressure washer and the lance should complete my growing detailing kit.
I can use my car to learn paint correction, before i respray.
thank rajab for the car behind me had better brakes! she would have wet herself, she looked pretty young, maybe around 17, I think she was more worried about hitting a skyline :P
I read....
Something something something a wet younger girl something looking at your skyline
And you didn't flag her down to get her phone number......c'mon man thats what young blokes are supposed to do.
  • Like 1
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
