Hi All,
I have a R33 GTST and i am looking to buy a bigger Turbo but need help decidiny what to get, i dont really want anything that will need a external wastegate or new injectors.
the mods i have r
3.5" Exhaust
Hybrid FMIC
Apexi Power FC
Air Filter
Fuel Cut Defender
i was looking at the Hybrid T3/T4, but would really love something bigger that wont max out my injectors.
if you can let me know what turbo, specs, price range and amount of boost i can run with the above mods, that would be great.
thanks guys
Craig
https://www.sau.com.au/forums/topic/41652-help-what-turbo-should-i-buy/
yea thats all god guys and id love to spend that much and i could but, i have been told if i put a T04 turbo on my injectors will MAX out at around 10 PSI, and i dont really want to get injectors, im after something like a T04 , nothing too big, or even a ball beariong T03/04.
i could spend more but i just want to spend a little for now, while i have heaps of other things on,
Would a T04 max out my injectors? i would like to run about 14 - 20 PSI ( in that range)
I was told I can put a 2535 without upgrading my injectors, someone here in the forum has done it and his injector duty is only about 85-90% from max. Not sure how much boost he runs (maybe 0.9 bar). But even a small 2535 has boost efficiency above 1 bar (14psi). Can't remember how much, perhaps 1.2 to 1.5bar.
Just get a good fuel pump, like a GTR one (cheap 2nd hand) or a new Bosch 040 if you can't be bothered to get 2nd hand parts.
I know you dont want to hear it, but even getting everything 2nd hand will come to more than $1,300. doing the turbo thing isnt cheap! when i did mine, like you i didnt want to spend much at all, but it just isnt possible. getting a small turbo (2530) needed the fuel pump and regulator to be changed, not to mention small things we all like to forget when performing this upgrade, like oil and water fittings for the turbo, intercooler pipe modification exhaust/dump mods, the list goes on.
i thought after i spent $1500 on my turbo that there wouldnt be much more to spend on the transplant - $500 in fittings and line - $300 for a reg - $400 for a pump $200 cooler pipes. it ends up getting pricey regardless of whether you go new or 2nd hand.
Maybe put the money away and save a little more so you can do it right the first time, it gets even more expensive when you have further plans down the track...
good luck with what ever decision you make!
I'm a bit confused :D
Do you just want a bigger turbo cause it's bigger, or do you want more power so your car's quicker?
Have you thought about what power goal your aiming for?
Once you workout what power you want, then you can look at what you need to do to get you there. Remeber that power isn't everything, sometimes the money is better spent on a good alignment and good tyres etc...
Just something to think about cause I think $1300 is going to fall short for a turbo upgrade.
J
BTW: A TO4 turbo won't be a bolt up turbo, so your looking at a different exhaust manifold and dump pipe, not to mention different oil and water lines :P
robos - no, no and yes
the only thing that bolt straight up are the manifold flange, exaust and intake pipe.
i had to get fittings for all water pipes, oil lines and intercooler pipe. so it ends up costing a fair bit
eav00l: Quote "if theree are anymore suggestions please let me know" Bendigo bank have some good interest rates if you deposit over $1000 get it in there and start saving :P
When I bought my car it came with a CGC stage2 450HP upgrade allready done to it, it's probly your best option as everything will bolt straight back up perfectly. I'm not exactly sure if my car has standard injectors or fuel pump and I cant check as it's getting work done to it and not in my garage, but I've seen the turbo pump out 16 pounds with no problems at all and comes on boost strong at 3,400 rpm and really throws you back, enough to spin the wheels in the first few gears without droping the clutch.
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
