Got a white series 2 r33 gtst I'm breaking.
Has complete interior.
Small tear on drivers seat.
Dash climate control all good.
Basically brand new splitfires. Literary on the car for 15mins then it was written off. $450
Tein ha front coilovers. Goof cond. $450
Front Lcas $150
Front hubs/ discs rotors $350.
Rack. Has new ends. $100
Cross member and mounts (steel) $150
Castor arms w super pro bushings $100
Complete front bar $300
Fiberglass guards $400 good condition fit really well
Bonnet $100
Got some other lil bits hear and there will update as I go
Chatswood
0419469108 msg for pics. Will put photo s up when I can asses computer
Cheers
https://www.sau.com.au/forums/topic/416550-breaking-r33-gtst-series-2-sydney/
forgot to mention car is non abs.
bonnet and front bar sold- pending.
front mount sold.
washer bottle sold.
gearbox/mounts and tailshaft sold.
alternator sold.
power FC has a tune for a highflow and usaual mods $850 w controller
non abs bm44 $50
Tein front coilovers good gond. no leaks, everything works adjustable dampeners $400
drivers switch ass. $40
Front five stud, brakes rotors $450. pads have heaps of meet. will throu in the hub.
fibreglas gaurds $350 pair. good cond. surprisingly fit really well
splitfire s $400.
hit me up for pieces i havent mentioned. still have more to put up.
and again, im in chatswood sydney.
0419469108
switch ass sold.
bar a bonnet sold
grill sold
drivers window reg sold.
centre console sold.
steering wheel sold.
cluster - pending.
still have front and rear seats pass window reg and trim. drivers trim.
still have front lights.
nissan strut bars
fiberglass gaurds.
both taillights, l/h side indicator lense has a crack in corner. right hand is good
have boot with wing (no brake light $100)
recently recoed radiator and good shroud $80
left hand mirror, faded slightly. works fine $50
pass headlight $150
driver headlight $150. will do pair for $250.
rear strut bar $50
left hand skirt $100. have the passenger as well but will need to be re painted/ or even repaired
ces type ? split dump 3 inch. merges back into exhaust. top quality
catco cat
from cat back its a 3.5inch system,genuine fujitsubo giken exhaust system and muffler w 4inch outlet. top quality exhaust $500
castor rods will super pro bushs $80
also selling a genuine Garret Gt3076 0.82 housed Ex Gated 4 bolt housing $1200- Has elbow welded to it for clearance on 1jz -still on my car and can be started/reved etc - 3-4000km use if that "track car"
Splitfires
Exhaust sold
Forgot to say have injectors supposedly they are 740cc they look like high flows.
Come in rail w reg. Spindles in top condition.
Also got a good coil pack loom. ( still soft)
Good full engine loom UN cut
Good injector loom
Castor arms $50
Tein front coilovers $400.
Lcas 150 delivered.
Cluster $40. Has 145k on it.
Clutch pedal $50
Standard coil packs $50
Standard seats $200
Door trims $40 each or $50 for pair
    • You’ll be very upset when you bust that too not to mention the gearing totally sucks. Don’t do it.
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
    • As MBS suggested if this is happening when the engine is cold you're going to want to remove the intake air regulator and verify resistance + that the shutter is physically opening and closing. At -20C should be fully open, 20C half open, over 60C fully closed. At 20C should be 70-80 ohms. For AAC valve testing using a Consult cable see if you can raise and lower the idle by commanding more or less AAC duty cycle. Hopefully it's pretty linear as well, shouldn't be like 30% AAC valve is barely idling and 40% is 1500 rpm.
