R34 GTT manual turbo
127,000k's
$13500
Engine
- Trust turn flow interooler (no holes cut)
- Turbo back exhaust (with silencer)
- High flow turbo (braided lines)
- Walbro fuel pump
- Power fc with HC
- Standard airbox
Exterior
- Nismo kit
- 18' avs copies
Interior
- SBC blitz boost controller
- Apexi boost gauge
Suspension
- Tein super street with damper
- Button clutch
Reg expires August 2013
Timing belt, water pump belts, clutch, spark plugs etc were all completed recently
Have receipts for everything
Body is in average condition, couple of dints here and there but still looks great, price has been reflected for that
Engine bay has been kept stock looking
Rwc was just obtained a month ago
Only just bought the vehicle but looking to upgrade
Will easily crack 250-260rwkw with a tune which was my next step
Currently has been tuned by RE custom making about 200rwkw on low boost
It is an extremely clean vehicle underneath and drives very smooth
Located Melbourne, Vermont
Will upload more pics shortly
0422 357 635
Dano
Edited by DFAULT
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
