Hey guys
I have a r33 and she has a after market blow off valve which i love but it screams out defect me...
Im looking for the stock blow off valve i found a r34 bov will that fit my r33? and in future im looking at running 12 psi will it still be ok ?
Cheers
Dean
https://www.sau.com.au/forums/topic/417600-stock-r34-blow-off-valve/
the stock bov should be fine for 12psi. you have to remember that it isn't just the spring pressure holding it shut against the pressure in the cooler pipe. it has a boost feed so the pressure on each side of the bov is the same. so while it is just the spring holding the bov shut, it isn't just the spring vs 12psi. it is the spring + 12psi vs 12psi. if you get what i mean, lol.
    • I've got a 2011 J50 that I imported six years ago. The unmodified factory AV system date and time has always been correct ( Japanese timezone of course ) up until last month. About two weeks ago, at engine start, the system wished me a happy new year ( in Japanese of course ). I can't think of anything that would make the system think that the date had changed, unless the GPS component has failed/reset somehow ? I checked the GPS reception in the system settings, and it can still see the satellites. Has any other J50 owner had this happen ?  It's no biggie, just annoying that it tells me the wrong date anytime I start the engine. 😅
    • Love following your adventures on IG, hopefully if you're still around in Japan when we visit again wouldn't mind going for a few beers with you (that's if you're keen on hearing how I hate Nissans).
