These wheels came on my v35
Toying with the idea of selling them as I cant help but change the rims on a car to make it feel like mine
I actually don't mind them as they are not whored out like most other rays
Specs are
Front 19x9.5+30 245/35/19 with heaps of tread left
Rear 19x10.5+37 275/30/19 have a fair bit of camber wear but heaps of tread on the outside
Centres are near immaculate with just scratches around wheel nut holes
The lips have had dodgy car wash used on them by the looks and have stains on the clear coat.
A polish gets some of it out but still quite noticeable
These retail for 80, 000 yen a corner so close to 1k each plus shipping from Japan.
Not expecting that kind of money but not going to sell them for $500 either
Can include a pair of 25mm spacers which makes the rear a it pretty much perfect for the stretch and slight poke on a V/Z chassis
$2000 offers
Less without front tyres as im staying 19's
Located South west Sydney
https://www.sau.com.au/forums/topic/418108-nsw-volkrays-gts-19x95105/
  • 3 weeks later...
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
