Hi guys new to SAU and unfortunately i'm selling my car :(
$23,000 ono. No more time wasters please!
Nis034 was built by the owner before me. He built as a track spec daily driver, she has had plenty of money spent on the best parts you can buy and it shows when you drive her. I've never had a problem with the car, I've owned it almost two years and it has never let me down! Bought the car with 75***km's and it now has 98***km's on the car and motor. Usual 5000Km services with Motul fluids, was tuned to run on shell Vpower 98 octane. The car was tuned by Trent at checkered tuning and runs 293rwkw, this car is not for the faint hearted! If your looking for a daily or a weekend cruiser with plenty of power and looks, then your looking at your next car! The car is fitted with a Viper pager alarm which features an auto start also has a flashing blue light from the pager which illuminates the inside of the car to warn any thieves that its not to be messed with. Selling only because I need to look at getting a house (girlfriends orders) the car is my baby and has been treated like a baby! If you have any interest, call me and we can arrange a time to view the car and I will take you for a drive. 12 months Reg paid 24th December, RWC will be supplied with purchase.
ENGINE:
-Blitz turn-flow intercooler
-Splitfire coilpacks
-Blitz 525cc injectors
-Walbro fuel pump
-Z32 AFM
-Greddy swirl pot (Air separator)
-Greddy oil cooler (Thermostat)
-Motul Nismo comp oil
-Koyorad 53mm alloy radiator
-Nismo thermostat
-Garrett 30/76.082 with braided oil/water lines
-Custom intake pipe
-Blitz front pipe
HKS HI-power cat back
MANAGEMENT:
-Nistune ECU
-Blitz ID3 boost controller
-Blitz power meter
GEARBOX:
-Redline shockproof
-Extreme heavy duty clutch(NEW)
SUSPENSION & HANDLING:
-Hicas locked
-Rear camber arms
-CST zero coilovers (10kg front/8kg rear)
BRAKING:
-Cross drilled and slotted DBA rotors
-Nismo R-tune front pads
-Bendix ultimate rear pads
-Motul brake fluid
STYLING:
-Factory fitted Nismo bodykit (Nismo Style)
-Genuine Volk TE37 18inch rims (Bronze) 8.5 inch front/9.5 inch rear. Fitted with brand new Federal tyres
CAR ALSO COMES WITH STANDARD PARTS:
-Stock intercooler
-Stock airbox
-Stock intake pipe
-Stock rear camber arms
-Stock exhaust
-Stock suspension
-Stock Hilcas motor
One of the last R34 GTTs ever made and is a very nice example and the plates (NIS-034) are standard victorian plates.
Please feel free to contact me on: 0432634680
:domokun:
Edited by NIS034
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
