(NSW) 2001 R34 GT-T 300RWKW – ZTUNE KIT- CARBON – APEXI – HKS – BLITZ
Up for sale is my 2001 Nissan Skyline R34 GT-T,
Former high performance imports magazine project car, many DVD and magazine feature articles. All work was carried out by Croydon Racing Developments.
Bodywork
*Fresh black respray
*Z Tune body kit including GTR front bar
*Carbon fibre boot lid
*Carbon fibre bonnet painted black
*Lowered
*JDM Decals
Engine
*RB25DET NEO
*146,000kms
*HKS internally gated turbo upgrade
*Twin entry front mount intercooler
*Split fire coil packs
*APEXI power FC
*Pod Filter
*4 Stage boost settings
*Fuel pump upgrade
*Blitz electronic boost controller
*Blitz RSM
*Complete turbo back exhaust
*Higher flowing cat
*Titanium tipped REGU cat back exhaust
Gearbox
*5 speed
*ORC super single clutch
Suspension
*White line sway bars
*Hicks lock bar
*Aftermarket shocks and springs
Wheels
*VARRESTOENS 18x9 +30 front
*VARRESTOENS 18x10.5 +30 rear
*Near New Tyres 265/285
Interior
*Omori gauges in factory gauge slots
*BLITZ RSM and EBC
*RECARO millennium bucket seats up front
*Very clean interior for its age
*Fusion front and rear speakers
*Fusion 10inch active subwoofer/amp
*Fusion USB/SD/Iphone/Bluetooth Head unit
Brakes
*Slotted disk rotors
Power
*212rwkw on 12psi
*296rwkw on 20psi/1.4bar
*500+ Hp @ Crank
*Ran a 11.9@Eastern Creek
Extra info
Very responsive setup, very reliable never had any issues in my ownership. Very fast car, not for the faint hearted. Plenty of clutch life left; lots of grip and does not slip at all. Tyres are almost new. There are probably more mods that I have missed out on. A full video of the build of the car can be found via the YouTube link. Slightly negotiable on price. Has fresh rego 6months. Car will be detailed prior to being sold. Comes with RWC. Interstate buyers welcome. No tyre kickers, test drive pilots. Inspections most welcome. Test drives after a non refundable deposit only.
Location
*NSW Sydney 2168
Price
*$22,000 or Nearest Offer
Contact
*PM, Inbox, Email @ [email protected] or Phone @ 96084459.
Ahhh my old run around i got the original boot lid here for it for anyone interested .
How did you manage to get the power upto 290kw+ ? We struggled to get past 265kw without it pinging ?
Will def vouch for responsiveness gun combo
Doubt that mate the turbo wouldn't physically flow more than 270 it was past its efficiency range I no this car inside out owned it for 2 years .
You also forgot to mention that every single bush has been replace with nolathane inserts the whole suspension is track orientated setup and is one of the best handling cars I have ever built any one who drove the car would tell you it handles like its on rails
Best of luck with the sale but I believe your tuner may have to recalibrate his dyno if those figures are being produced
  • 1 year later...
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
