$14,000
...because this Manual Rexxie Engine has just done 200***Kms
Ph# 0416214699
* All services done (using full syn oil) and logged + 7 months Rego
* Engine is stock - never been tracked
* Number plates come with the Foz
* No damage or rust. Just a crack on driver's side mirror housing
* Diff back s/s exhaust with nice Rexxie burble and no drone on hwy
* XYZ Coilovers near new with 30 settings
* New front brake pads + spare rear pads
* Whiteline 22mm rear sway bar with HD links
* Ultrex front strut brace
* Nudge bar
* Narva lights
* Side steps (removeable)
* Tow bar - only used to tow SAU.NSW trailer
* Momo gear knob to match steering wheel
* Blue tooth
https://www.sau.com.au/forums/topic/418533-forester-m-y-0-6-x-t/
MY06XT will be up on a hoist (for camber adjustment) next Wed 13th Feb if one wishes to inspect underneath.
...or on top. The stone dent/scratch on the aluminium bonnet has been already repaired and repainted.
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
