  • Replies 60
Posted Images
last aerial SOLD
mirrors SOLD
tailights $70 pair
boot $40
Headlights $200 pair (2 sets)
Sunroof complete set up $300
front and rear brake set up ON HOLD
taking offers on everything!!!!
need this stuff gone asap Shell $300 will come with a heap of crap on it left rear quater hit not worth ixing ideal for front cut :P
Te 37s $1000!!!!! Will take parts as trade. Chasing a mech 2 way. Rb25 clutch anything for a s14 tracker
Blitz coilovers $700 same deal as wheels may trade
Climate control $40
Dash surround $50
Diff $100
Front lca's $150 pair
Heaps of stuff here!!!
Headlights sold pending payment (that's both sets gone)
Reo SOLD
a.c. fan SOLD
drivers window motor SOLD
drivers window relay SOLD
fan shroud SOLD
may swap red jackets coil packs for stocks + $200
Stock radiator $40
Stock cooler with all piping $60
