hey jsut wonderin if you made these or had them made or where they came from
im lookin for a manifold for a RB30ET conversion on a R31 and instead of payin 2-300 for a stock manifold, maybe lookin at a custom one for up to say 800
can u help in any way
thanx
Keishi
  • 4 weeks later...
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
