Hi guys !
My radiator tank has a crack on it,keeps leaking. Went to couple of radiator place, some suggested repair others said replacement.
What is a good replacement brand ? Probably something local and reasonably priced!
Car is used for everyday driving so probably not looking for a "race" radiator.
Had a look at ebay, most of them look dodgy .lol..
Also, which one is better, the plasctic aluminium or full aluminium ??
Thanks!!!
https://www.sau.com.au/forums/topic/418835-r34-radiator/
What ever you get, just make sure it can fit the standard fan shroud fine.
I had my plastic stock one repaired (replaced top plastic tank) when it broke instead of getting a new one, but that was only bcause my car is auto & it had connecters for connecting to the auto box, which most aftermarket ones don't have & I didn't want to get another seperate cooler for the slush box.
https://www.sau.com.au/forums/topic/418835-r34-radiator/#findComment-6727656
Hi guys !
Thanks!!!
I have a series 2 r34 low km clean stock 5 spd one
50 bucks plus shipping its yours
https://www.sau.com.au/forums/topic/418835-r34-radiator/#findComment-6727760
There are heaps of options, heaps of big thick cores you can get for cheap, Koyo single cores on ebay can be had for just over $500 delivered, Racepace triple pass radiator for $550 or you can just buy a stock replacement..........
https://www.sau.com.au/forums/topic/418835-r34-radiator/#findComment-6727770
https://www.sau.com.au/forums/topic/418835-r34-radiator/#findComment-6728400
Hey Man!
Mine one is a N/A Auto, i beleive yours is a GTT. I will check with my mechanic and see if a GTT radiator fits n/a's .
If it does, i will get back to you.
Thanks !!
https://www.sau.com.au/forums/topic/418835-r34-radiator/#findComment-6728729
I bought mine off here: http://www.ebay.com.au/itm/NISSAN-SKYLINE-R33-R34-93-03-AT-MT-RADIATOR-/270948181614?pt=AU_Car_Parts_Accessories&hash=item3f15c5266e
Great quality and has barbs for auto box. $180 is very rerasonable and is slightly thicker than OEM as far as I remember. But fits perfectly with shroud, no mods.
https://www.sau.com.au/forums/topic/418835-r34-radiator/#findComment-6737817
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
