Hi Guys,
Up for sale is a HKS cast iron twin scroll manifold, in T4 and drilled/tapped in T3. Its a proper twin scroll, that separates both the turbine, and wastegate gasses. Also included is an old school style HKS 38mm wastegate (unknown spring) and I'll toss in a genuine Air Research (Garrett) T04B turbo in 0.63. Basically everything you see in the pictures.
I originally bought this with the intention of building up a track car. I ended up getting a SR20, so this is surplus. I have not mounted it, or used it. Turbo appears to be in usable condition, and spins freely, however its really old tech (made in the UK!) and you should put something newer on if your going to do it properly. Put the turbo on your coffee table or whatever.
Note - the manifold has cracked in the usual place that these crack - the divider in between the two chambers. This should not effect performance at all, and is not an external crack. See the photo. Its common place with these manifolds.
PRICE: $500.00 FIRM.
Its what I paid, and its what I want back. Search and see what other people have asked- you'll see this is very reasonable.
Willing to post at buyers expense but it will be heavy you have to understand.
Preferable contact is via PM because I do shiftwork, but mobile is 0431 zero 90 240
Pics:
Thanks for looking.
Far out you sold this way too cheap mate
These usually go for $800 with no waste gate
Wish I had seen this, would have found a way to get this in 2 secs
Tom, that's not really true... There are a few for sale atm.. there are 2 being sold (by retailers) for around 1k but they are without cracks, with wastegates and other extra's. There is one forsale on sau for 700 but it is cracked and has a copy wastegate that I made an offer on.
The last couple I sold were under 400 each with wastegates.
Deals done, sold to me..
Didn't see your post up these
Glad to see another stagea owner managed to scoop it up!
Let me know if you don't want it anymore!
SOLD
PM sent.
I think the price was fair for both parties. As I said, its what I paid for it. I don't want to make money off people, just get money back. Rather sell fast and fair than post stupid prices :)
Hope your C34 enjoys it.
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
