Hi Guys Just Wondering How Much i would get for my 1993 r33 GTS skyline na manual Unregistered & unroadworthy ( not far off tho )
It has just had a full respray in 2004 skyline silver got rid of the two tone
it has 18" rims (four stud unfortunatly)
3" Cat back exhaust system
runs beautifully
(NOT SURE IF THIS IS POSTED INTHE RIGHT THREAD IF NOT IM SORRY)
MESSAGE ME OFFER NEED A ROUGH IDEA OF HOW MUCH IM LOOKING AT GETTING FOR IT
https://www.sau.com.au/forums/topic/419208-1993-r33-series-1-na-manual/
sorry bro do i just edit it and put a price because i wanted to know what i would b looking at if i sold it
Edited by AlexWaltham
yea man....
theres rules and stuff to follow. just look on gumtree etc to find out what they are worth. dont have to apologise mate, just thought i would let you know before the mods lock it.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
