It's time to put my 34 up for sale , details are as follows.
788 x 523 (125.22K)
800 x 533 (98.52K)
499 x 473 (38.93K)
1024 x 682 (95.9K)
Model: R34 GTT ER34 1998
Engine: RB25DET NEO
Colour: Athlete Silver (metallic silver with wild violet)
ENGINE:
KM: 185000
Internals- stock - Moroso Accusump, ARC Oil cooler and after market Power Steering cooler. all using speedflow fittings Installed by ERD
Oil filter relocation kit, agin using speedflow fittings. Installed by ERD
Turbo: Stock
Exhaust: Trust 3" turbo Back, Hi-flow Cat, no resonator and a cannon muffler
Injectors: Stock
Head reconditioned at 100,000km. compression accross all cylinders is above average and very even.
DRIVETRAIN:
Gearbox: converted to 5 speed manual - R34 gearbox used not R33.
Clutch - NPC Heavy Duty Organic 300kw Installed by ERD
Flywheel - Stock
Royal Purple diff oil and gearbox oil
MODS:
Ecu: NIStune 260rwhp - tuned by EFI performance
Intake: K&N pod filter / custom box
Boost Control: Apexi AVC-R set to 7psi low / 13psi high
FMIC: D1 brand and big
Fuel System: Stock
HICAS lock bar Installed by ERD
Aftermarket big rear wing
interrior trimmings colour matched to car
NISMO style vinyl kit with custom colours
Suspension:
Tein HR coilovers with adjustable dampeners
JJR rose jointed front castor arms
Whiteline adjustable front toe bushes
Whiteline swaybars front 24mm Blade adj
Whiteline rear 20mm Blade adj
Whiteline adjustable rear camber arms
Whiteline adjustable front camber kit
Whiteline cradle bushes
Whiteline swaybar links
Electrical:
Apexi turbo timer
5" Autometer tacho with shift light
Drift brand gauges
Pioneer head unit with USB input on the front face
Sony 280w 6.5" splits front
Pioneer 260w 6.5" splits rear parcel shelf
Pioneer 260w 6.5" 3 ways rear doors
12 inch US audio subwoofer in boot
Kenwood 700w amplifier for speakers
Kenwood 400w amplifier in boot for subwoofer
HID headlight kit, 7000K colouring
Wheels:
Koya RG TEK 18 x 8.5 +35 front
Koya RG TEK 18 x 9.5 +38 rear
flush fit
Tyres:
Front - Archillies 235/35R19
Rear - Archilles 265/35R18
Brakes:
RDA Slotted/dimpled front and rear - Stock Calipers Installed by ERD
Project Mu B-Spec pads rear
Brakelabs brake pads front
HEL braided lines
Motul brake fluid
Car is serviced every 5000km with full synthetic HPR oil (SIN 5 and now SIN 5 equivelant)
Ever 10000km car suspension is inspected to fulfill Whiteline parts warrenty and safety.
car is kept in garage not out in the weather and is well maintained. no fluid leaks of any type.
Bad points: scratches on rims, scratches on front bar, right rear guard has a crack where lips were rolled. Other than that it is general wear and tear.
Price $14,500.00
Contact CLint on 0414 799 723 if interested.
https://www.sau.com.au/forums/topic/419209-1998-r34-gtt/
    • Yes that’s what im trying to decide. Should I do stock gtt box or enclosed or open pod.
    • Also, I note OP is in Melbourne, which begs the question... are you aware of how illegal your car will be with a turbo, and intercooler and any sort of filter change? I don't know how you can get past the "2 intake mods" "rule" that seems to exist in Vic. Fully engineered might or might not get you there.
    • If you have a turbo... then the ducting holes I used to feed the pod are not available because your intercooler likely uses them. If you have an intercooler, your IAT's are going to be goverened by how good your intercooler setup is. I'm yet to really see anyone check IAT with a snorkel/boxed pod/proper CAI versus and unshielded pod. It would be interesting! But I suspect that the differences would not be so noticeable as if you were N/A as the intercooler is where the air is being cooled.. and out in front where the FMIC would be is a pretty good spot for it.. When I was turbo I pushed the stock GTT box as far as I could and made some pretty good power out of it, and noticed on the street I never made the same power/boost. Then I did a before and after run with a pod filter versus the box and picked up about 9PSI from the same boost duty cycle and about 50KW instantly. I never ran the stock box again, and recently removed it for my N/A setup. The box is restrictive to a degree - Even with the V8 setup I noticed I picked up power by removing the box completely, so punching holes from the bottom of it to get air from the passenger guard *helps* but the most effective one in my case was simply having the ducts, a pod, and no box around it. In my experience, *more* air was better than cold air. The air (with ducts) will be cooled off as you start moving, and especially if you start moving fast (a race track). It actually moves around quite a bit as you can see.
    • Well you could certainly buy or build an enclosure for a pod in that corner of the bay. It is absolutely vital that there is a nice big opening to let cold air in to it from the front or underside, otherwise it will just pull air in around the edges from the bay, and if that air is hot, you gain nothing from enclosing the pod. There is lots of good evidence around (including on here, see posts by @Kinkstaah for example) showing that pods pulling hot air from the bay is only a problem when you're static or slow in traffic, and that as soon as you get the car up and moving the air being grabbed by the pod cools down. Although that will obviously vary from car to car, whether there is a flow of cold air to the pod or if it all has to come through the radiator area, etc etc. Obviously, the whole exercise requires as much thought as anything else does. Doing the lazy thing will often end up being the dumb thing. The stock GTT airbox has a cold air snorkel to feed it from over the radiator. Shows that Nissan were thinking. The GT airbox is upside down compared to the turbo one, yeah? Inlet at the bottom, AFM/exit on the lid? That might make it harder to route the turbo inlet pipe using the GT airbox than a turbo one. That would probably be the main reason I'd consider not using it, not that it is too small and restrictive. I'm looking at a photo of one now and the inlet opening seems nice and large. Also seems to have the same type of snorkel that the turbo one has. Maybe all that's required is to make a less restrictive snorkel/cold air inlet, perhaps by punching down through the guard like I did.
    • Also seen this as an option
