Z32 ecu has been nistuned for a r33 gtst. Only removed because of upgrade to vipec ecu. Perfect condition.
Located wangaratta can post any where.
Price $450 FIRM
CONTACT ME ON 0400215126 SMS prefered.
https://www.sau.com.au/forums/topic/419418-z32-ecu-nistuned-for-r33-series-2/
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
