Hehe thanks!
I love this true story from Broome
"A tourist caught himself with a HD hook whilst angling. He couldn't pull it out without major damage, so he got himself to the local base hospital. The attending nurse said that the Dr was off for the afternoon but she'd try and get him on the mobile if he was within range. Fifty minutes later the Dr came up to the tourist whilst still bare chested, in board shorts and sandals. An incision via a local was about to commence. The tourist then said, "You don't look much like a Dr" to which the Dr replied, "And You don't look much like a fish"".
Hope things are still fine!
Thinking of you atm whilst my wife is getting scans and then sees oncologist in a couple of hours.
Meanwhile here at Norwest Private a man walks out of a cardiac ward > sees me > talks to me as if I'm his cardiologist.
Why do people think that just because I'm chinese I must be a doctor? I'm wearing sandals FFS!
So I send him to a dementia unit - jk
Maria is clear! Many thanks folks! :)
Best of luck with your wife any news? Btw I thought u were a doctor too lol. The high level stuff still hurts a bit but hopefully will improve with time at least I'm not dead, seriously though life is tough this year has been a constant struggle in almost every level, on a basic level I havnt seen my Gtr in 3 months! I will hopefully get it back this week and start the clutch change :-( it's stuff like that it just keeps mounting, then staff leaving, being sick forces me to work 70 hours again which I really don't want to do but nobody wants to work hard anymore! Anyway as I said could be worse and terry I hope your wife gets the all clear.
Scott
  • 1 month later...
Thanks heaps Scott. Any more news?
All clear with wifie...
Asked her if she'd like a cruise to NZ at Christmas/NY but she declined.
Maybe she guessed it was just therapy for me - lol
Hope your pains diminish Scott!
Keep us updated pls!
Event Archives > R34 GTR 10th Anniversary
Also in Motive DVD #3
And HPI Mag #113
And lol, Daily Telegraph 17/4/09
Beyond Blue wouldn't be party to this event because they regarded it as "risky"!
McGrath Foundation accepted monies with both hands :)
The R33 GTR 21st Anniv is in 2.5 yrs Scott.
But hey, we can arrange something early next yr I'm sure :)
I'm thinking what about a run to wisemans? Start at crossroads costco to thornleigh Maccas then old road to somersby to wisemans then Windsor somewhere then home, should cover a big area of members that way , any thoughts? Maybe late jan or early feb?
Scott
I thought I'd heard that admin costs Scott were to be open and transparent and accessible to the public; eg Salvos Bushfire Appeal is going to be zero admin costs, compared to Aust Cancer Council admin costs being fairly high. McGrath Foundation admin costs at Willoughby are supposed to be low.
I wonder if there's some database.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
