  • Replies 127
Hi All,
It was great to meet new people and put faces to them. I had a ball driving behind the slightly quicker cars :whistling: lol
I would like to thank Anthony for putting together a great drive and thanks for Matt for putting up some awesome pictures!
Hi All,
Thanks for making the effort to come along mate! Great too meet you and see the beast! Look forward to catching up on future cruises :D
Was a great run, thanks to everyone for turning up, especially the sydney guys making the extra effort, well done.
Ran well all day untill the lunch stop, i apologise for the crappy organising there with the take away etc, next time we can stop elsewhere with a pub that serves food ha
Hope to see you all at the next one.
I know.
wtf was with that?
pub that doesn't do lunch on Sunday.
pfft, oh well, burger was good.
next time, talk to pub owner and let them know a heap of people are coming for lunch.
he may get the chef in.
or, just go back to the takeaway.
was pretty good food.
next time, will be in the wifes 3, to try and keep up.
Luke's 'lux was great. You don't see many of those around any more.
thanks.
You don't see any being driven that hard I would suspect.
my wife wasn't happy with me trying to stick to the speed limit.
Awesome picks mat, keep them coming.
where's the lux?
Well the person with the camera was a bit busy drooling over/in the R35 hahaha..... Hence why their arent many from this cruise ;) Post up your pics?
    • That is way more science than even I would use. I just eyeball it, not even accounting for the non-verticality of the tape measure when held on the lip and the centre at the same time. +/- 2mm is good enough for the girls I go out with.
    • So, before putting them in I need to understand the stock ride height. This is how I measured it: First, check the diameter of the wheel's centre cap, it was 52mm. Then put a piece of masking tape approximately across the centre and measure 27mm (half) from at least 3 sides to get a reasonable idea of the centre of the wheel cap. Mark that with a horizontal line as one measuring point. Then, directly above the wheel on the guard, put another piece of masking tape in approximately the centre. Use a string line to find out the point on the guard above the centre of the wheel cap and mark that. Then it is simple, just a tape measure to check the distance from centre of the wheel to the centre of the guard. Final results where  LF: 381mm RF: 379mm LR: 401mm RR: 400mm Pretty even considering they are 120,000klm old factory springs, lets call that 380 front and 400 rear.
    • So....knowing that I have a problem with power steering temps on track and another Wakefield day booked in next Friday, I've done the obvious thing They are very reasonably priced at $1650, considering they are a big monotube shock, double height adjustable (don't have to change pre-load to change ride height), one way adjustable damping and standard sized and customisable springs if you want something other than what comes with them. They come with 9kg/mm front and 4.5kg/mm front and I went with that as a starting point because I'll add adjustable sway bars too https://justjap.com/products/bc-racing-coilover-kit-ds-ds-infiniti-q50-v37-14-current#description Unfortunately they didn't come with rear strut tops so I've re-used the factory ones which was a bit of a pain. Also, the adjuster for the rear shock will be an absolute nightmare to get at, and while there are extensions in the kit I can't see any way you can actually attach or use them
    • I also had 2 bulbs blow at once, years ago in the stagea. made for a fun drive home. The issue was the voltage regulator had failed in the alternator and it was giving 15+ volts. Really, I was lucky all that was fried were the headlight bulbs. So, I'd suggest you check the voltage across your battery terminals with the car running and warmed up. Yes, you will need a multimeter to do so, sorry.
    • Good work to think to check that, and thanks for coming back to post up the outcome.
