Hello SAU!
Time to put my pride and joy up for sale. This car has been apart of my family for the past three years. Bought off a mate, it's just had a full rebuild completed which is a shame as i wish i could keep the car! Working in the city, i'm in need of a more suitable daily driver!
It's just had a complete engine rebuild with details below. Currently running the engine in with just over 1,000km's on the clock. Chassis has done just over 155k.
The engine is immaculate with potential of around the 280kw mark with no hesitation of all day-everyday action safely!
Run down of the car:
Engine:
RB26DETT - R33 block acid dipped, x-rayed, bored and honed
Head rebuilt with all clearances set
JE Pistons (20" over) - BRAND NEW
Eagle Rods - BRAND NEW
PowerFC
Garrett Dash 7's - BRAND NEW
Siemens 570cc Injectors - BRAND NEW
Tomei Adj. Cam Gears
Gates Racing Timing Belt & Kit - BRAND NEW
ARP Head Stud Kit. - BRAND NEW
ACL Race Series Bearings - BRAND NEW
Tomei Sump Baffle - BRAND NEW
Tomei Oil Head Restrictor - BRAND NEW
Tomei Extreme Dump pipes with 3" front pipes and full system.
Split Fire Coil Packs
N1 Oil Pump with crank collar - BRAND NEW
Koyo Aluminum Radiator - BRAND NEW
Bosch 040 fuel pump - BRAND NEW
All genuine gaskets used with COMETIC Head Gasket - BRAND NEW
Replaced hoses with all genuine pieces - BRAND NEW
Suspension & Driveline:
Tein Coilovers a little old but very nice to drive on.
New K-Frame bushes and subframe bushes - BRAND NEW
Daiken Heavy Duty Full face with a approx. 3,000km bought new.
Cusco Castor Rods - BRAND NEW
Interior:
Momo Steering Wheel
Momo Gear Knob
The rest is stock and very clean. No rips or tears (have another seat with no tears). Comes with genuine GTR mats.
Running 17x9 Sparco Vipers.
I'm certain i've missed out on bits and pieces but if interested and would like to chat some more feel free to give me a call any time on 0422947769.
All work has been carried out by Robert Sabbadin @ Sabbadin Automotive in Mulgrave, Melbourne.
Price: $19k ono.
Cheers,
Ben
post-10384-0-97736300-1361331297_thumb.jpeg post-10384-0-67641900-1361331341_thumb.jpeg post-10384-0-43599700-1361331388_thumb.jpeg post-10384-0-73609000-1361331409_thumb.jpeg post-10384-0-55194700-1361331426_thumb.jpeg post-10384-0-79922200-1361331445_thumb.jpeg post-10384-0-62797600-1361331459_thumb.jpeg post-10384-0-82860100-1361331476_thumb.jpeg post-10384-0-87219800-1361331498_thumb.jpegpost-10384-0-48928600-1361331520_thumb.jpeg post-10384-0-44558900-1361331542_thumb.jpeg
Edited by IFRYCE
  • 10 months later...
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
