'A tune' is not a fixed thing... so it's hard to shop a price for 'a tune'.
Nick at GT is good at what he dose and depending on how much time he spends doing what with your car will depend on what he charges you... it's not very common that a car will roll into his workshop with zero issues/problems etc and only needs 'a tune'.
Just go have a chatt with him, do as much of the preperation work your self as you can and book it in.
Cheers
Justin
Mainly I just need an idle and boost spiking fix as the person who tuned my car struggled with those 2 things as he usually only does power fc's. I didn't have the problems before the tune so I am guessing it's in the tune. Thank you Justin :)
They're usually the two most time consuming things to get right... Idle issues could be almost anything and as for boost, I'd just install a turbotech boost T and solve all your issues all at once.
What else did you change before the haltech install and initial tune? I'd be looking at pressure testing your intake and looking for leakes/split hoses and or missing vac lines.... clean your iac motor etc and making sure your intake is all sealed up properly.
What's the idel doing?
Cheers
Justin
The initial tune didn't have those problems, this is the second haltech tune but by a different guy.
The idle is just dying (mainly if you put the clutch in at 3k+ revs) and will stall at times or come very close.
The changes from initial haltech tune to this one:
850cc injectors
garrett 3076r turbo (with custom stainless intake)
bosch 040 pump
nismo fuel pressure regulator
I had heard boost T's were prone to boost spiking, is this just a myth?
Beau, in honesty you have changed alot between tunes.. you will probably find that your idle issues are as much mechanical in nature as anything else. Do you still have your stock bov? is it plumbed in as standard? are you getting reverb back through the new intake causing map sensor spikes, is your tps set correctly?
Nick can fix it for you, just don't expect a tune will be the solution... sounds like the tune needs a good looking over though.
A turbo tech boost T is as reliable as you can get.... just don't buy any other type/brand of T. Again, Nich has them on the shelf.
Cheers
Justin
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
