I'm tidying up the garage and its time to give some of my stuff a new home.
All items located in Pascoe Vale, Melbourne. If you like what you see, make me a (reasonable) offer.
4x Rays Gram Lights 57 Pro in Greyish Silver 2 Piece. 18"x9J +12. Include near new 265/35R18 tyres.
Great condition, no curb scarring at all only a few marks on them where nuts have been dropped while fitting. Include brand new Rays centre caps.
$2,200 set.
IMG_1510 by flyingfridge, on Flickr
IMG_1511 by flyingfridge, on Flickr
IMG_1512 by flyingfridge, on Flickr
IMG_1515 by flyingfridge, on Flickr
IMG_1516 by flyingfridge, on Flickr
IMG_1014.jpg by flyingfridge, on Flickr
IMG_1025.jpg by flyingfridge, on Flickr
2x Velo Podium Racing Seats, side mount. Include rails for Skyline.. Also have other rails of unknown type, possibly BMW 3 series.
Great condition with minimal signs of wear. No tears or holes and lumbar & under thigh cushions included. Only selling because I returned the car to stock interior.
$900 for the pair and all rails & mounting brackets.
IMG_1494 by flyingfridge, on Flickr
IMG_1495 by flyingfridge, on Flickr
R33 GT-R stock turbos. Pulled off the car at 95,000km, no shaft play evident.
$600 pair.
IMG_1497 by flyingfridge, on Flickr
IMG_1498 by flyingfridge, on Flickr
IMG_1499 by flyingfridge, on Flickr
HKS High Power stainless steel exhaust. Has Magnaflow twin tip rear box, HKS cannon is included in the sale.
$550 the lot
IMG_1504 by flyingfridge, on Flickr
IMG_1506 by flyingfridge, on Flickr
IMG_1507 by flyingfridge, on Flickr
IMG_1508 by flyingfridge, on Flickr
IMG_1509 by flyingfridge, on Flickr
Pioneer 12" Sub in genuine box.
$95
IMG_1500 by flyingfridge, on Flickr
IMG_1502 by flyingfridge, on Flickr
  • 4 weeks later...
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
