Apexi 161AN001 N1 EVO Exhaust System BRAND NEW IN BOX & BUBBLE WRAP.
Removed from box for trial fitting only, mufflers still in bubble wrap. Have decided to custom build exhaust rather than use this one.
To suit 95-98 Nissan BCNR33 Skyline GTR & GTST
Pipe Diameter.: 85 mm-95 mm
Tip Diameter.: 115 mm
Will freight at buyers expense. Box measurements for you to work out postage cost:
2500cm L
30cm W
52cm H
Approximate weight - 10-15kg (can weigh if need be, just estimated)
Pick up available in Shepparton, can deliver to Melbourne for cost of petrol.
More info taken from web:
"The N1 Evolution combines all the racing heritage and proven performance of the original N1 muffler but raises the ante by adding light weight, fully polished stainless steel piping. This is the ultimate N1 exhaust system. Mandrel bent, full stainless steel construction provides maximum power gains and resistance to rust or other damage caused by weathering. Like the original N1, the N1 Evolution uses the minimum amount of pipe bends to allow for greater exhaust flow. The N1 Evolution was created for those who are looking for something one step further than the classic N1 design. Available only for a select amount of vehicles, the N1 Evolution stands as a brilliant testament to exhaust system fabrication.."
$700 ONO - Negotiable.
https://www.sau.com.au/forums/topic/420688-fs-brand-new-apexi-n1-exhaust/
  • 3 weeks later...
  • 3 weeks later...
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
