R33 Series 1 And 2 Stock Parts. Make An Offer. Going Cheap!
I have the below parts for sale. Make an offer. Stripped a few cars and got many little parts left over.
got other boxes full of shit i havent looked through yet. Sing out if there is something u want i dont have listed. Very keen to get my garage back.
make an offer. will deal for several bits. have pics of most parts but not wasting everybodys space with them. just ask.
Purple passenger mirror 25
purple door driver 50
purple rear bumper bar 40
airconditioner condenser 70
random aircon hoses ask
power steering rack
70 hicas rack 70
speedo cluster 192km 50
radiator shroud 40
washer bottle 20
rubber gearbox gearstick cover 15
shifter surround 30
kick pannell 20
s1 rear trims 30
gearbox flex plate 30
NA brake callipers think rear 70
jack 30
bonnet latch 30
aircon compressor 70
charcole canister 15
silver driver side tail light 35
low + high pressure power steering lines 40
clitch master + clutch line 60
clutch master 40
coilpack loom 35
horns 20
aeriel with cable 40
some skyline mats not full set 30
bonnet cable 30
under steering wheel colum cover 20
clear skyline rear tail light garnish 30
random nissan clutch slave. Unsure what it fits. Maybe sr? 30
rb25 gearbox shifter with gear knob 40
r33 centre dash vent undamaged 40
space saver x 2 30 radius arm rods 40
right hand side front lca control arm 40
r33 half shafts left and right 60
injector loom 30
s2 abs pump motor 50
s1 wiper indicator stalk 30
s2 wiper indicator stalk 40
s2 passanger airbag 40
centre radiator / bonnet catch support 40
radiator overflow tank 30
driver side a pillar 25
brake and clutch peddle 40
r33 metal window seal. Bolts to car above door 30
sunroof motor 30
light with sunroof control 25
interior light 20
hand brake cable
20 several clock springs 30
glovebox 30
airbag computer 30
climate control units 30
brown windscreen wiper relay box 30
illuminted ring for round ignition barrel 20
amber side indicators with silver surround 20
aircon reciever dryer 35
battery hold down clamp 20
top radiator holders 20
single din sized pocked for under radio 20
heaps of seatbelts 25
several starter motors 35
tyre iron 20
windscreen wiper motor 30
ecu bracket 20
  • 1 month later...
Hi I'm chasing up a air bag steering wheel for a 95 skyline, just wondering I'd you have one. If so call or txt me 0417438691
Edited by Chopper888
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
