no havent done the brake mod,ive tryed higher boost cant hold it , starts creeping
that would help a lot on launch it made a big difference for me awhile back was getting the high 13's as i forgot to flick the "magic switch"
I can launch at around 17psi but does creep and start spinning the rear wheels a bit which i only noticed in my videos.
don;t know any one to do it, as i wouldn.t do it my self, trouble is by boosting high on launch, i have a factory ecu so it will only drop down
usually 7psi
not that i've ever checked psi but i know i launch on boost i do it by ear and before the point that the wheels spin...if i rev too high i get the same thing mentioned above...rear wheel spin...the last run of the night i did this...trying to get a hold of the video of that
I have done 15psi launches on standard ecu. Even before doing brake cut mod.
  • Like 2
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
