nissan s13 part out let me know what yous need
engine ca18det with new acl metal head gasket
compression test was done and got 150 psi though all 4 cylinders here some parts
all panels available car is complete here are some parts
after market radiator with new hoses
intercooler
apexi pod filter
z32 air flow meter
gtr 444cc injectors
modified intake manifold with r32 tb
t28 turbo
boost controller
after market fuel pressure regulator
split fire coil packs
oil catch can
manual gear box with new clucth
blitz bov
3" exhaust front pipe with high flow cat stainless steel modified to fit the sr20 t28 turbo
engine damper
gktech metal bash plate
lsd diff
nistune ecu
exterior
*after market corner lights and front bar indecaters
*aftermarket alteza rear lights
*drift teks 17*8 all round
triple projector headlights
silvia grill
interior
*gtr front seats
*180sx door trims and glove box with factory option cool box
*type x rear seat
*digital climate control
digital speedo with hud display
type x leather stitch steering wheel
silvia factory option floor mats
suspension and brakes
bm44 master
cusco coilovers
front stut brace
controll arm brace
fender bracing
in cabon floor brace
diff brace
white line rear sway bar
s15 front calipers pads recently changed slotted front rottors rear brakes have new pads and cross drilled slotted rotors
call or text me if interested 0432-062-780
will let you know the prices located in melbourne
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
