Hey all clearing out the storage;
Got standard R34 GT shocks and springs for $50 ono
Rear Bilstein shocks and lowered springs for a R34 GTT $50 ono
And my SSR Type C wheels, with near new tires all round, nice and wide clean and painted white. Fronts are 17x8 and rears and 17x9 - 5 stud.
$800 ono for wheels and tires
Text me if you like 042 446 1348 or reply on here
https://www.sau.com.au/forums/topic/422912-ssr-wheels-with-tires-and-r34-bits/
Hey mate to be honest I wouldn't have a clue, I was just told they were lowered springs when I bought them for my 34...Never been on my cat though because they didn't fit my GT. I dont know much about springs but these seem okay...not the cleanest visually with a bit of the paint flaking off the shocks but they dont seem to be leaking oil at all and the springs look good
Located in North Lakes which is 30 minutes north of Brisbane
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • BRUH, one of the biggest mistakes of my life..... and i've had plenty ;[)
