Once upon a time, far,far in frosty Siberia a man having come out to fend off a bear, bullying in his backyard, stealing his balalaikas and matreshkas somehow found himself in a gt-r without engine...no,no,no - It's NOT the story !
...exept for, i really bought 1995 BCNR33 with huge hole in situ of motor.
Okay, you never have a second chance to make a first impression, but i hope i succeed at some extent.
My name is Dima, i'm form Saint Petersburg, Russia, place where you cant find gt-r spare parts and experienced grease monkey, there are 2 or 3 running gt-r33's in my 5 million city, so it's very rare, exotic car for north-west region of Russia.
I really love JDM stuff and i'm happy to own my car.
Hope you wont be too strict to me and share tiny bit of your massive knowlege.
Na zdorovie !
https://www.sau.com.au/forums/topic/423452-ooopsrussian/
Welcome.
Hopefully you can learn a lot from the forums and build yourself a decent engine!
Thank you sir.
I began to build already, now i have many problems of how and what.
Maybe I should start a diary,but i hesitate if it worth of it.
https://www.sau.com.au/forums/topic/423452-ooopsrussian/#findComment-6818447
welcome.
diarys can be helpful.
possibly start a build thread in the build up and projects topic.
theres alot of useful info on here, and some not so useful info.
just have to keep looking and keep an open mind.
good luck, and hope you have success.
https://www.sau.com.au/forums/topic/423452-ooopsrussian/#findComment-6821586
welcome.
Big thanks Luke , gonna do that.
https://www.sau.com.au/forums/topic/423452-ooopsrussian/#findComment-6821817
    • LOL, all of the CAI like Craig I just need to put a hole saw through my bumper Done and dusted, the car runs, which is nice, I'll take it for a spin when the weather clears up Just need to put the bumper back on for good
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
