in tank fuel pump standard wire -
each 044 pump has own wiring apart from, wire from battery splices to each relay the rest is individual wiring from relays to pumps
wire roll says 3mm 10a
hope what i am describing makes sense
Edited by Reese69
  • Replies 48
The setup sounds fine, just need to make sure you are running the right gauge wire. Does it look like this:
3mm 10a wire:
Or like this:
8-gauge (round about 50a) wire:
That 8-gauge wire is the absolute minimum I would feel comfortable running from battery to relay for a single pump. If I was splicing that wire into relays for 3 pumps I'd be using 4-gauge wiring, which would admittedly be overkill but wire isn't such a great expense that I feel the need to be stingy about it.
10a wire is whats generally used...
8 gauge is way overkill... :woot: not to mention really thick and hard to hide around the car.. besides, how do u crimp and wire it to relays etc?
On a setup that can potentially see over 20a just in normal operating conditions, 10a wire is never going to cut it. Look at this:
These pumps draw 15.29 amps just at base fuel pressure. Hence why Resse69's 10a wire burnt out.
8-gauge is not that big, it's your general sound-system size wiring. Not that hard to get around the car, in fact when I had amps and my battery in my engine bay I had three 8GA cables all running the same route and they were invisible. You don't want your wiring to be the weak point of any electrical setup, but especially not in your fuel system.
As for wiring, that's easy. Use a horn relay with big terminals, and connectors to suit the wire size.
As mentioned, 8 gauge isn't hard at all to use. I can't remember exactly but pretty sure the wiring should be capable of double the intended load. Not to mention reese had burnt out 10a wire numerous times, how can you say it is ok?
Edited by superben
    • HFM BM57 has a "bad" knee point, IIRC. It's not the same thing as the later R chassis MC.
    • The ATTESSA is functionally identical to R34; there were a bunch of JDM models that continued ATTESSA including Fuga/Q70, Skyline/Q50, Cima etc as an option. All with Auto only and I think mostly for snow regions. AFAIK there were no AWD VR30DDTT sold in Australia - it is on my to do list to check regs for racing a LHD car in Targa/ATR/AASA/CAMS events because if I can get the auto to work it would be interesting to run a 4wd car The Ecuteck TCM tuning is the same model as their ECU tuning, they already have it for R35 and Dose's favourite, BMW. You buy "points" to allow your computer to be tuned, buy either a bluetooth (phone app) or bluetooth+USB+Key (phone and PC) dongle, and pay for a tune that will be locked to your tuner ( ). You can also access the tuning software yourself but 1. it is mega expensive and 2. these computers have a billion parameters that intersect, so how could you ever spend enough time on it to get a decent result.
    • Or, is it a case of what it is like owning an R series Skyline? NFI what the previous owner has done or fiddled with... Ha ha ha After reading through this thread, I went on a bit of a research about the Q50/Q60. Now I'm quite intrigued by them! Is the AWD in them more like a WRX where it's always AWD, or is it more like the ATTESSA in the GTRs? By the sound of this TCU tuning, this sounds like a case of someone has made some real software for it, and you just need the right piece of hardware, and then you license that specific vehicle/TCU. Or is this a case of the software will be really expensive so only a few tuners have it, and you still have to pay a license per vehicle?
    • No, code 21 is very straightforward. It can only be the things described in that diagnostic flow. In fact it has no way of knowing that the spark plug resistance is out of spec.
