Just after some info on this turbo and set up.
I has a t25 flange instead of the t4 flange which i have sorted,
Will my standard dump pipe connect to the turbo.
How much will my standard injectors hold with bigger fuel pump
and fule pressure regulator,
How much possible power could i expect to make on this set up.
A lot of question but i picked up the turbo cheap cheap. so going ahead with it.
Cheers heaps
https://www.sau.com.au/forums/topic/425503-hks-gt2540-on-rb25-neo/
injectors are on the list but dont have the yet, will get the at some stage, just want to get the turbo on with fuel pump, fuel preassure regulator and z32 and custom intake.
so they should be able to handle 230 rwkw?
It all depends on what you want from your car. However, i think GTR injectors are low impedance and GT-T injectors are high impedance. (can someone confirm this)
If you think the power bug will bite, even if you just make the switch from 98 to E85, i would just go for some ID1000's. They are relatively easy fit for a neo from what i have read, plenty on the forums about fitting them.
If not, just get a set of direct fit sards, nismos (insert brand here) 550's it will be a lot easier in the long run.
yeah ive been looking at some bosch ones. just gonna have to lay the cash out!
The power bug bit ages ago coming from a 338 rwkw vz ss and a twin turbo ve ssv
to a nistuned 34, been a long time waiting, wont ever go back to a v8 though
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
    • List all of your mods. It sounds like an aftermarket ECU hitting rev limiter. Like a valet mode, or a cold rpm limiter?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
