Hello ladies and gents..
I have few leftover bits from my long gone R33 series 1. Taking room in the garage and giving my folks an excuse to start a fight for taking up room so I need these gone ASAP. Located in the Hills area, Sydney.all prices neg..would be easier to contact me on 0405095954 for any questions,,cheers Hoody
Fujitsubo Giken exhaust in excellent condition includes a dump pipe,mid pipe and muffler, no dings or major scratches, all you need is a cat to bolt in, this system sounded excellent in my car and wasn't too loud but had nice deep roar in it when throttle was applied: $200
Pair of factory series 1 seats in excellent condition, no tears or holes, comes with rails (seats were stored sitting on each other so they little squished but little airing them should sort that out): $100 for both
Trust style front bar in flexible fibreglass and in excellent condition, comes with mesh aswell, bought this originally for $300, after couple of years due to car being low it was all mangled up, took it back and got it refibreglassed to new condition for another $200,,,then i breifly had it on car and then took it off,,so its like new,,comes with custom brackets to mount on,,,can also help to put it on $200
series 1 silver colour bonnet,,some surface scratches which should buff out,,straight bonnet $100 ..also second marron bonnet with little ding at front of it,,,free
pair of series 1 headlights,,these have some of the mountings broken but were glued back on and work,,the lenses were taken off as experiment but can be put back together,,great for parts or to repair and seal them back up $50
also have rear right disk and calliper,,$20
https://www.sau.com.au/forums/topic/425659-r33-bits-syd/
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
