One of a kind 240z. This car has been built with no expenses spared since 2004 from ground up. If your into the classic JDM cars I'm sure a car like this would be on your list of affordable cars to experience once in your life time.
384208_10151011967437330_1539298151_n.jp
390496_10151011952172330_2120652015_n.jp
Engine:
2.4L rebuilt, balanced and bored to 2.8L with mild cam.(N42 block with E88 Head)
Triple 40mm webbers set up by Stewart Wilkins Racing
SWR extractors
Electronic Ignition
Dyno'd at approx 116KW at wheels (weighs 1060kg)
Running gear:
Arizona coilovers revalved bilstein shocks from Heismans suspension
4 pot Wilwood Brakes Front
Disc brakes Rear
Stock front n rear sway bar
Rose joint front sway bar end links
Rose joint front caster rods
Rose joint front adjustable control arms
Rose joint rear adjustable control arms
Front top strut brace
Solid Diff mount
Complete bushing replacement of all bush points from steering busings to rear diff moustache bar.
New engine and gear box mounts
OSgiken LSD
Stewart Wilkins 5 speed with 1:1 fifth gear ratio (his now selling them for $12,000 per box). Dog leg 1st gear.
Wheels:
Original Watanabe's 15" by 8"
Toyo R888 semi slicks
Body:
Ground up paint work with all rust removed.
Paint colour is Championship DC2R white
ZG Flares from Spirit garage in Japan (not some ebay reproduction)
Polyurethane front spoiller with brake ducts
432z front grill
No dents or dings on the car at all.
Interior:
4point rear roll bar
Recaro carbon fibre Drivers seat
Recaro fibre glass passenger seat
OMP steering wheel
Mild strip down but underbody heat shield to reduce cabin heat.
As you can see this car has been built for the purpose of being a weekend track car. Since it was finished though in 2007 it has seen only 6 track days. Happy to ship interstate. Please enjoy the pics but do not call unless you have available funding for purchase. As you can see this was a moderate budget build and I don't expect to even get half the money back hence realistic with sale price.
Best time to call is after 6pm and weekends.
Selling due to needing rear seats for my little 2.5yr old on those family wkend drives.
Free camping bag thrown in so you can set up tent next to it and enjoy it after purchase :mrgreen:
Price:$38,000
0402136861
Cheers,
Will.
Edited by MKI4EVA
https://www.sau.com.au/forums/topic/425734-syd-fs-1972-240z/
Hi Will,
USA is mad about these.
Have you contacted Iron Block (aka Iron Chef) to research whether or not to advertise the "Z" over there > export it to the US?
Cheers, Tez
    • Hey guys Long time lurker, I daily a nm35 stagea 250t rs four and I've had it for almost 2 years (very reliable 👌). Issues or just looking for information ill always find myself here having a read, so thought id join.  3inch stainless intake, pod filter, AM performance turbo dump pipe, 3inch hotdog, 3 and half inch stainless to 3 and half inch AM performance blast pipes. Bc racing coilovers. 18inch rims Hdi intercooler and trans cooler soon.  Here's my car
    • thanks for the advice on the box... i was thinking the 6 speed was better for cruising on the highway but on closer inspection and comparison the Rb 5 speed box was not too different...  So the choice is going to be the RB25 box... if I can save up and find one at the right price
    • Thanks Matt, yes that's what i am aiming for. Just going to apply the right voltage and grounds to the dash connector. Hence my search for these pins... any chance you know if these pins are in the same spot as the ones on the S15 Dash connector? as mentioned above on page 8?
    • Yes, unfortunately that's the one. Signal was noisy to begin with; after driving once and looking back at the logs I saw pressure constantly swinging between 0-200psi, or staying at 0 randomly for a few seconds. There's a lot of good sensors that share the same look and feel, so don't presume they're all bad. I bought mine for 20$ off Amazon and I should have read the reviews prior, as it's clear they're junk.  I purchased a lowdollerr motorsports sensor.
    • wedding eh.....I seem to get to more funerals than weddings or christenings these days....
