Very interesting build mate. Can say I have seen this car around before! Tough car keep the log going :)
Again. Thanks for the good words. I appricated positive feedback.. even though it isnt a Skyline or even a nissan! Where have you seen it around?
Having real problems now..
I keep looking at Widebody kits... O_O
ARGH! What to do...... FUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUU~!
Edited by Tonba
Cool build Tonba. I've grown a real soft spot for evo's lately. Did the stockish setup of the 8 get boring too quickly or were you just modifying it without any real plan to begin with? I only ask because I'd like to own an viii myself one day when I sell the sky.
Thanks copycutter.
I originally set-out to build a car to do street duties, run consistant 12's at the strip, and 1:08's at Wakefield.
(Remember this was 5-6yrs ago, when 98RON was the norm and a 1:06 @ wakefield was consided SUPER quick..)
I managed to get 220kW, low 13's (13.1-13.2 sec passes) and a high 1:08 @ wakefield., but the engine developed a problem with the lifters and oil-rings so we decided to rebuild. From there things just snowballed. I kinda lost my way with no real plan, and ended up with a car that simply was not fun to drive on street - Im sure #@34GeeTeeTee can help me elaborate there...
After just too many engine/tune issues, and now hating on the car, I took the car to JEM and they found major issues with the engine build.. So the decision was made to 'start from scratch'. Every item I am picking is to build an absolute street monster..
The NEW goals are;
-Street Car, Understated but turns heads
-Run in the 10's in the quarter mile in FULL STREET TRIM (ie street rubber, synchro gearbox and all)
-Run a 1.04 to 1.05sec lap at wakefield.
Edited by Tonba
If it didn't have issues when it was at 220kw do you think you'd have still gone full house eventually? Is that a common fault with evo 8's or were you just unlucky?
If you knew this clown you would know the answer! He is halfway through one build and already planning the next :P
Look, 220kW was very fun on the street, and with e85 it only would have been better. I never ment to go FULL-RACE spec. I just got carried away. But I was always going to build a serious street car.
It isnt a common problem. Just very unlucky.
Guilty as Charged...... :P
Already trying to talk myself out of a Wide-Body Kit & Twinscroll HTA3586R.
Edited by Tonba
My 250kw nugget kept up with you so you wanted MOAR :P That is the true story haha
Just shuddup and stay on target!
You speak the truth. If it wasnt for you mate, who knows what the hell I'd be doing... the car that NEVER runs because its just constantly getting modded. lolz
Hence why you will get the build and paint done and get it back on the street to enjoy! Now get more engine part pics etc online! Carnage and all!
No worries champ. When I get more pictures (particularly of the head) I'll post. At the moment I have nothing new to show.
Lol you two are classic egging each other on.
Why do you think he went to a HTA turbo? ;)
He#@34GeeTeeTee forsaw the need for more power... Scared I tells ya!
Edited by Tonba
Haha Good mates for many years.... Always a good way to get shit done! :P
I have pictures of Carnage! Dont make me post them!
Car head's over to bodyform today. Currently looking into a Varis carbon fibre roof... Depends on timing really. If I can get the roof in 4-5 weeks I might do it.
I think I have decided on colours, but going to paint a test first to make sure while the body is being prepped.
I WAS going to look a widebody, but it now looks like I wont be. Too difficult, and will loose the very 'stock' understated look I'm going for.
Engine wise, not a whole lot is going on. Rods & crank delivered, pistons still being made which will be finished in a week or two. The head has finished getting portwork done, and is currently getting assembled with the valve train. Still waiting on photos. Either way, Ill get photos and post them up when it is delivered which should be before month end.
With the old engine setup, we ran a standard sump with tomei baffle plates, but with the new setup we are considering a Moroso/AMS fabricated sump which has extra baffles to make sure oil stays where is should, and an extra 1.4L of capacity. To go with this, we are also considering a Moroso/AMS accusump, which has another 1.4L of capacity. If and when oil pressure drops during extreme cornering or acceleration, the accusump automatically pumps extra pressure into the system to make sure everything is well lubricated. The additional benifit with all this extra oil, in addition to the twin oil coolers, there should be NO TROUBLE in keeping oil temp's in check.
Edited by Tonba
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
