My AAC valce on the back of my plenum does not have any wires going to it. I went down and bought a plug for it today but I need to know which wires go to it from the rb20det ecu. I know that 1 of the wires is from no.4 pin on the ecu which is labeled AAC valve, however it does not tell me what the second wire to the plug should be, nor does it tell me which wire goes to which pin on the plug. I am pretty sure in thinking that the no.4 pin from ecu goes to the no/1 pin on the AAC valve but I am not sure.
Could anyone please tell me what the second wire to the AAC plug is and where to get it from
https://www.sau.com.au/forums/topic/426352-rb20det-iacv-aac-valce/
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
