well
after all my stuffing around and damaged knuckles i cant get the fly wheel off - i am borrowing a firends impact driver air gun, but i still am stuck on locking the fly wheel - can anyone pm some help something visual if possible
thanks in advance
Where are you?
Locking the flywheel? Do you mean to hold the flywheel while you undo the bolts? I use $40 electric rattle gun (Dicksmith, Jaycar, Supercheap) to undo the bolts. If I don't have a rattle gun, I use a large screw driver on the wheel teeth, braced so it doesn't move.
https://www.sau.com.au/forums/topic/426576-flywheel/#findComment-6884636
yeah thats what i am doing but keeps slipping - but i have a rattle gun coming this arvo hopefuly works -
i am more worried about doing it up (dont they need to be done up evenly 150nm)? guess that is the main time i need it to be locked - guess ill keep trying to lock it with different ways
https://www.sau.com.au/forums/topic/426576-flywheel/#findComment-6884706
When you do them up, put a socket on the crank bolt and brace against the body. Just do them up like a wheel, it's not super important like head work.
https://www.sau.com.au/forums/topic/426576-flywheel/#findComment-6884913
Yes the ol socket on the harmonic balance locks it good.
And yes use a torque wrench to do it up properly, its real tight and you know you got it with the torque wrench.
If it comes off it can cut your legs off, so dont fk around.
Ps, i never got a flywheel off without a rattle gun.
https://www.sau.com.au/forums/topic/426576-flywheel/#findComment-6885003
I AM WEAK LOL
No no no, its impossible without real good leverage while your jammed under there and can hardly move your arms let alone get a good strong push/pull.
Eiji is just very persistant, and had a very long breaker.
Dont forget to be super clean with the clutch, or it may slip.
Anyway, the hard bit is getting the box back on, that will test your patience. So be careful with the input shaft, its easy to bash it into the clutch plate or springs while trying to get it into position.
Doing the clutch up evenly takes ages too. But worth it.
Good luck, hope it goes smoothly.
https://www.sau.com.au/forums/topic/426576-flywheel/#findComment-6885436
YEAH NPC told me to use some thinners or break cleaner on the clutch and or fly wheel surface to be clean as possible and clean the shaft and put very little amount of grease on the shaft..
https://www.sau.com.au/forums/topic/426576-flywheel/#findComment-6885477
    • From the factory on RB26s there's a fitting on the intake manifold collector/"plenum" that provides pre-throttle boost signal. That's how they did it back in the day, I figure it's fine to replicate it.
    • I would be surprised if that wasn't the issue. It's probably telling you, that even if you remove the plastic liner, you may have some other clearance issues that may occur too in some scenarios. IE, tyre to guard. It looks like someone has already rolled the lip, but you may still have issues in the future IE, turning and hitting a bump etc. The fact it changes how bad it makes the noise when you are going backward vs forward is highly indicative that it's the tyre rubbing. They do make a terrible sound, even if you're only pushing a project car that has a liner hanging down on a tyre!   Has the car been lowered? If it has been, what is the measurement from the centre of the wheel hub to the lip of the guard straight up?
    • Summernats cruiser?
    • Mark's a bit smarter than people give him credit... He'd convince the person that is to become dead, to drive him to the forest first. That way his car has no evidence in it, and he's free to dispose of their vehicle permanently how he sees fit too...
    • But if you had to go bury a body in the forest, would you not put that in the boot? Most of them are >=90kg these days.
