Hi I am pretty sure I have a bad boost leak I blew an intercooler pipe off hitting 15 psi in second gear I then put the hose clamp back on the rubber fitting and tightened nice and firm and ever since then it has only made about 1 psi of boost, u can't really hear the boost leak in the car but when idling with the bonnet open you can hear it sucking while the engine is under vaccume it sounds like its coming from the inlet manifold around the far right hand side would I be right in thinking that it could be the inlet manifold gasket it seems to have a thicker gasket than usual its about 3 mm thick or is that normal ?
Cheers
https://www.sau.com.au/forums/topic/426632-rb25-boost-leak/
yes the plenum gasket is about 3mm thick, after constant issues im fitting a cosmetic gasket recommended by KudosMotorsport, im quietly confident it will solve the issue. Apparently this is a common issue when running high boost, mine was sounding like a cat Meowing under boost.
Edited by AngryRBGTX
https://www.sau.com.au/forums/topic/426632-rb25-boost-leak/#findComment-6883036
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
