Have two skylines at the moment and one needs to go. Wanting to start doing some club events / sprints etc and don't think i can bring myself to potentially destroy this car.
As the title says its a 1993 GTR with all the necessary mods. With this car the expensive part is done its time for the new owner to just use and enjoy!
Car still looks standard and goes very well. Vehicle is still daily drivable if so desired and exhaust is not to loud.
I have included a build list and have most paperwork for build.
Also as you can see interior is very good for age. no cracks, no bubbles, no rips.
Car is in NSW Hills area.
Chasing 20k
Car has done 135km
Engine,
Arias forged pistons,
Hardened rods,
Tomei gaskets, Head gasket and all manifold gaskets
Tomei Sump baffle
Tomei Oil Restrictor
Greddy polished hard piping kit
Greddy Oil Filter relocation kit
Greddy adjustable cam gears
Greddy alloy pulleys
Splitfire Coils
Gates timing belt
Nismo Thermostat
Nismo fuel pressure regulator
Brass button clutch
Lightened flywheel
Exhaust
HKS split dump pipes
HKS front pipes
JUN catback
High flow cat
All new Nismo engine and gearbox mounts
Standard diff rebuilt
Electronics
Apexi Power FC
Apexi AVCR boost controller
2 x Z32 Airflow meters
HKS Tourque Splic controller
HKS Drag adapter
Suspension
Tein adjustable coilovers
Fulcrum adjustable front arms
Fulcrum Adjustable rear arms
Whiteline sway bars front and rear
Cusco tension rods
Front and rear strut braces
HICAS Four wheel steer lock out bar
Brakes
Front DBA5000 discs
Rear DBA4000 Discs
Endless pads front and back.
Stereo
Sony Headunit with Bluetooth
Focal speakers front and back
Wheels
Brand new 18 x 10 wheels and tyres.
If interested please call 0400 841 142
Edited by CHO50N
  • 3 weeks later...
    • Maybe it's time for a M3 F80 LCI, and leave it stock.  Drive it to a shop, sip on your latte with nutmeg whilst it gets serviced and on the way home swing by and grab some chai mix for the evening.
    • Great work! Thanks for documenting the process.
    • How would you even adjust the clutch if the pedal already has the correct free play? The operating cylinder has no adjustment in mounting position or rod length. On pull style clutches there is also no ability to adjust the bearing carrier. Push type I can see how adjusting the carrier height makes it all work.   If this is the twin plate clutch did you verify that your friction disks were oriented correctly? It's not mentioned in the directions at all you just have to notice that one side the friction disks have a part number on the hub fingers and a subtle coning to those fingers. Another thing that I noticed was if you put the friction disks in backwards the pressure plate fingers will not be even and flat when the clutch is installed.
    • yeah, mechanically, it is probably do-able, off the top of my head, there would be the transfer case, which I believe will bolt up to the rear of the RWD transmission, the shorter rear tail shaft. A front drive shaft, front diff, engine upper sump, front drive shafts, front hubs and front AWD struts (they are shaped around the front drive shafts), LCAs (at the very least from the front suspension) oil cooler.  You might want the rear diff from an AWD too, so you can be certain the front and rear diff rations are identical.  Who knows what brackets and mounts you might need.  So a whole doner car might be the best option if you need to maintain RHD. Then actually making it work, that would be a whole different story.
