so in second and third if you get it up to baout 4700 4800 rpm it starts to go from the ususal brrrrrr to bdrbdrbdbrbdbrbdbr kind of sounds al lose acceleration and just pretty much peak
what could be the cause. ask if more info is needed
its a 1994 r33 rb25det
https://www.sau.com.au/forums/topic/427101-r33-spittinglosing-powed/
Once your airflow reaches a set level as measured by the Air Flow Meter it will richen your fuel map and retard the timing to protect the motor. This is assuming you have the stock ECU of course
And while the coil packs mat be new the loom probably isnt.
I would
1. Change plugs.
2. Clean the contacts in the coil packs between the pug and the coil pack AND coil pack and loom
3. Use the contact cleaner on your AFM element
If the problem persists turn your boost down until it stops, you are effectively reducing your airflow below the threshold doing this.
if it still persists think of ordering a new loom from nissan
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
