Hey guys,
Looking to sell my 1990 SW20 GT.
Really awesome car, have done a bit to it and the previous owner has done heaps more than that to it. Due to lack of money, and the amount that I have already put into the car I can't afford to keep her unfortunately, I need to sell and get another car, maybe a skyline or integra for my everyday drive. I'm looking for $6000 but am happy to work out a good price for serious buyers. Also, if I can get the ECU working, the price will go up.
The good parts are:
- Have had an imported engine put in which happened to have a few issues, so under the warranty the shop had to recondition the whole engine. So essentially a new engine.
- New turbo
- Air to Water cooling. Much better than air to air cooling.
- Custom racing exhaust.
- Engine bay cooling fans.
- Turbo timer.
- Autotechnica racing wheel
- 17" Enkei Mags with near new Falken Z-series tyres (done aprox 1500km).
- Pod Filter - Roof Scoop
- 6.1 Pioneer Speaker system
- Kenwood CD player
- Pop out monitor (can be used for reverse camera, tv or dvd player)
- TRD short shifter - Glass Targa Roof (the roof comes off and stores behind the seats).
- After market suspension (King Springs I think).
The not so good parts:
- The biggest issue is the ECU, when the mechanics did all the work on the engine something has happened to the ecu and they are not taking responsibility for it. This is the main reason the amazing price as it is a bit costly to get a new ECU.
- Drivers side power window doesn't work. Could just be the switch.
- Electric mirrors don't always adjust.
- Seats are a bit worse for wear.
- Paint could do with some work in some areas, although it is still respectable and isn't really a huge deal.
Apart from the above things, this car is amazing!!! One of the funnest cars out there to drive, mainly because of its mid engine mount and the amazing traction it has. Selling due to lack of money to fix ECU. There are a few things that need doing, however, those things taken into consideration, this is an absolute steal
May be interested in a swaps, however it needs to be a working car with a rwc. Happy to put a bit on top if I can.
ECU is an unknown at the moment, tried to reset it to factory settings and the car isn't turning over. Still a good steal if you can get a ECU an know how to install it.
I'm based in West Brisbane
Thanks for looking :)
https://www.sau.com.au/forums/topic/427265-fs-1990-mr2-6000-qld/
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
