So, This is currently on (my guess is) deck 9 of the Morning Miracle, on it's way to Port Melbourne... for me!
I'm not a workshop guy, so I need help here.
A few things....
1: I need a workshop in Melbourne that won't charge me the earth to maintain it, but will do a great job, especially the first checkup.. it's just a daily.
2: it has lowered springs... do they seem too low to you? will that hurt it over time?
3: THOSE WHEELS!!!!
Anyone in the market for some REAL Venerdi 19" Chrome 5's .. :P (currently fitted with 245/40x19's
I am looking into replacement wheels, not sure about fit etc though. 19x9.5 ... just want them to fit.. not really into the whole "stance" thing...
4: The Works Bell paddle mod.. it seems easy enough.. is it reliable etc? this is the first car I have ever risked going auto for!
5: maybe that's enough for now!
https://www.sau.com.au/forums/topic/428582-incoming/
That's a sweet ride you've got there! I'd be careful going up steep driveways as it looks as low as mine.As for workshops.......f**k that,i wouldn't let any of those monkeys even peer through my windows let alone look under the bonnet.Get onto Scotty he is the man when it comes to these things and is always willing to help a brother out.Good luck on the wheels!
https://www.sau.com.au/forums/topic/428582-incoming/#findComment-6926225
As mentioned by Gleeson, get in contact with "Scotty M35". Mechanics in Vic don't even know what these cars are, they're not technologically advanced or should we say bout 10 years behind the rest of the world.
https://www.sau.com.au/forums/topic/428582-incoming/#findComment-6926513
    • If true then....wierd. That's a very high base fuel pressure for a shitty old early 2000s Nissan.
    • I may have my math slightly wrong, I'm not double checking that again, but the factory spec for fuel pressure is to set it with the engine IDLING (in vacuum). That spec is 51PSi while idling. So now add +10psi for atmospheric, and +7 for 7psi of boost, and we need 68psi of fuel pressure at full noise, and 51psi idling. That's according to the FSM I found last night for M35. So MINIMUM fuel pressure should be 51psi and it climbs from there.
    • Provided that what you see makes sense and is not "linear" between, say 1.9 and 2.1 volts and that's the whole range you get. You still need it to be doing one end of the 0-5v range at one end of travel, and the other end of the 0-5v range at WOT.
    • So just calibrate whatever voltage the closed position and full throttle position is and check linearity ? Sounds good to me
    • go look at the live data, and slowly open and close the throttle, if it is moving in a linear fashion, just do a re-calibration. OR if you really want to, adjust the TPS position so it's under 1V (no need to be bang on a 0,45V, it's not a stock ECU), then recal. Job done, rip skids, post it here.
