FOR SALE is my R33 GTS-T nissan skyline.
Engine: 2.5L inline 6 cyl, turbo.
Asking $7200 (negotiable)
I'm a longtime lurker on this site, and the community has helped me over the years with maintenance issues and projects. The community also helped me find my skyline, and now its time to give it back and move on. Its truly a great car and I have no doubts it will please its next owner.
Sleek Black with subtle-tasteful mods.
NO TROUBLE WITH THE POLICE! - all mods are street legal. The car itself has the stock body kit but due to large 18" rims looks much lower (stock kit is 10cm from legal limit anyhow). The Rims arn't flashy or showy at all, which is exactly why I like them - subtle. Custom modified stock bumper for maximum airflow to the Front Mount Intercooler, which also has model specific piping to prevent having to cut into the firewall at all.
Thousands spent on cosmetic as well as performance mods - Custom Moulded fibreglass Sub box in the boot along with the Pioneer splits and singles inside pump amazing sound. Fresh fluids, new brakes, new tyres (less than 2000km on them), etc. the whole lot.
Mods as follows:
-Model specific FMIC
-Custom modified stock front bar (no cutting of reo bar)
-3" Exhaust including HIGH FLOW cat
-5" Stainless exhaust tip - sounds AMAZING
-Exedy heavy Duty Clutch
-Turbo Timer
-Boost Controller (although running stock boost)
-Neon Blue digital Boost Gauge
-18" Rims - low profile tires
-Bosch Fuel Pump (rated up to 500HP)
-HKS Pod Filter
-Complete Sound System (Pioneer Front Splits, 12" Infinite Competition Sub in custom box with wall mounted amp in boot, 6" Pioneer Rear speakers)
-Keyless entry, Alarm with 3 point Immobilisation
-Aftermarket Steering Wheel
-Red brake calipers
Still has original Skyline Carpets.
Finishing University and moving away, and the car must go. If I was staying I would keep it, it runs great has had all regular maintenance done, and I am sad to see it go.
Asking $7200. All reasonable offers considered, the price is NEGOTIABLE. RWC included.
Contact Rob.
(04) 5233 6588
[email protected]
or send me a pm, but i don't always sign in everyday.
https://www.sau.com.au/forums/topic/428902-1994-r33-skyline-gts-t-for-sale-qld/
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
    • Any idea where I can get genuine MAF apart from used ones? I can't find any only for GTRs and unfortunately that price is not in my budget 🤣 I might gap my plugs down and put my splitfires in, they were only in for a year or so before I started the rebuild
