Measures 2000mm between the guards, take up to a 2850mm wheelbase, 1450kg car. Smooth riding full shackle rocker suspension, registered, five new Sunrasia wheels and tyres, over ride disc brakes, protected LED lights, dual ratio winch, etch primed Algal chassis. Built by a pro as a keeper and way better than an Ebay cheapie, now $1000 under factory price, sell for $4215. Phone Richard 33543204 or email [email protected]
  • 3 weeks later...
Trailer wheels and tyres cop a hiding, this trailer has new Sunrasia wheels which have heavier rims than old car wheels plus it has new light truck tyres including the spare.
  • 3 weeks later...
  • 2 months later...
  • 1 month later...
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
